Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
diabolique0007
0
ERROR:Xst:785 line 26: Type must be constrained for this object : 'sys_memory1'.
I get the following error when i synthesize my code:
INTERNAL_ERROR:Xst:cmain.c:3483:1.56.16.1 -  Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Line 26 is a signal declaration:
signal sys_memory1,sys_memory2:array_type3;
And array_type3 is declared as:
type array_type3 is array(integer range 0 to 2147483647) of std_logic_vector(7 downto 0);
I don't understand why the error says type must be constrained when it is already constrained?
Expert Contributor
rcingham
0
Re: ERROR:Xst:785 line 26: Type must be constrained for this object : 'sys_memory1'.
The error message may be misleading...
You appear to be inferring 2 * 2G * 8 bits = 32Gbits of memory.
What device are you targetting?
How much memory does it have?
diabolique0007
0
I'm trying to implement a system memory of 4 GB.
Expert Contributor
rcingham
"I'm trying to implement a system memory of 4 GB."
In an FPGA?
diabolique0007
0
I'm not sure about that as I won't be doing that but still I have to be sure that my design is synthesizable.
mcgett
0
[ Edited ]
There is no way to be able to synthesize/implement a 4 GB memory inside of any FPGA.  You need new code.
Have you tried typing your question into Google? If not you should before posting.
Expert Contributor
eteam00
0
Or wait about 7 years for Virtex-10, perhaps?
-- Bob Elkind
SIGNATURE:
Summary:
