0
FATAL_ERROR:Portability:PortDynamicLib.c:358:1.29
FATAL_ERROR:Portability:PortDynamicLib.c:358:1.29 - dll open of library
<> failed due to an unknown
reason. Process will terminate. For technical support on this issue, please
open a WebCase with this project attached at http://www.xilinx.com/support.
Process "Synthesis" failed
win xp sp3,ise 10.1.03
0
Re: FATAL_ERROR:Portability:PortDynamicLib.c:358:1.29
There are relevant hits on this message if you search the website:
http://www.xilinx.com/support/answers/32123.htm (10.1i ISE - Project Navigator fails opening a 10.1i project: "FATAL_ERROR:Portability:PortDynamicLib.c:358:1.29)
http://forums.xilinx.com/xlnx/board/message?board.id=ISE&thread.id=4127 (ISE: FATAL_ERROR: Portability: PortDynamicLib.c: 358: 1.29 - dll ...)
If these don't resolve it, I would open a webcase as suggested:
http://www.xilinx.com/support/clearexpress/websupport.htm
bt
0
libcs.dll already copy from lib\nt to bin\nt. it's ok to open software . but when synthesize, crashed
my system variable like these:
D:\Xilinx\10.1\ISE\bin\nt;D:\Xilinx\10.1\ISE\lib\nt;%LMC_HOME% \lib\pcnt.lib;D:\Mentor\EE2007.2\2007EE\SDD_HOME\common\win32\bin;D:\Mentor\EE2007.2 \2007EE\SDD_HOME\common\win32\lib;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\system32 \WBEM;"C:\Program Files\UNA-1.0";C:\Documents and Settings\RenXiaoFeng\My Documents\我的快捷 方式;%QUARTUS_ROOTDIR%\bin;%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT% \tools\fet\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\tools\pcb\bin;%MGC_HOME%\bin;% MGC_HOME%\lib;%MGC_HOMEBS%\bin;%MGC_HOMEBS%\lib;D:\Rational\common
0
why slash and back slash appear in <D:/Xilinx/10.1/ISE\lib\nt\libGenXstTask.dll> at same time?
0
has you get a solution for this problem?
0
Hi Jrheredia,
you can find more similar cases in the forum and in our answer record database.
Please do a search on our support page: http://www.xilinx.com/support/mysupport.htm on "FATAL_ERROR:Portability:PortDynamicLib"
Typically it is an install issue or wrong (conflicting) environment variable settings.
After consulting these forums posts and answer records and you're still unable to resolved the issue, please run xinfo and post your xinfo log file on the forum for further help.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
