Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
sdaau
0
Accepted Solution
WARNING:Xst:2677 and explicitly unconnected ports in Verilog (alternative to VHDL OPEN)?
[ Edited ]
Hi all,
I'm trying to use a Verilog module - however, I do not need one of its outputs at the moment, so I wanted to explicitly declare it unconnected - like using the OPEN keyword in a port map in VHDL. So I read in Verilog HDL Syntax And Semantics Part-II that the syntax for explicitly unconnected port is ".pad()" - so I have something like:
versatile_sd_counter wptr1_cnt
( // synthesis attribute keep of .q is true; .q(), // explicitly unconnected port .q_bin(wq_bin), .cke(wcke), .clk(wclk), .rst(wrst) );
 When I try to synthesize this, XST barfs with:
WARNING:Xst:2677 - Node <wptr1_cnt/q_4> of sequential type is unconnected in block <my_module>.
WARNING:Xst:2677 - Node <wptr1_cnt/q_3> of sequential type is unconnected in block <my_module>.
WARNING:Xst:2677 - Node <wptr1_cnt/q_2> of sequential type is unconnected in block <my_module>.
WARNING:Xst:2677 - Node <wptr1_cnt/q_1> of sequential type is unconnected in block <my_module>.
 ... and I'm like: "yeah, I know - I specifically wanted to leave it unconnected" :)
The thing is, I'd like XST to instantiate everything in hardware "as if" something was connected (say, output OBUFs, I guess) - however, I'd just like to keep those output elements "open" for the moment. Would that be possible somehow? As you can see, I tried using "attribute keep", however, that doesn't help much... If that is not possible - is there at least a way to suppress these warnings (without completely removing .q - also from the source of the underlying module?)
Many thanks in advance for any answers,
Cheers!
EDIT: Just found Unconnected Ports | Comp.Arch.FPGA | FPGARelated.com, and judging by the sentiment there, it is likely not possible to suppress these warnings :( Can anyone confirm that?
EDIT2: Just found unused wires and VHDL architectures (comp.lang.vhdl), and thought I should try adding a dummy signal, so I did:
// synthesis attribute keep of unconnected1 is true;
wire [8:0] 	 unconnected1; // dummy - unused/unconnected hack
  .q(unconnected1),		//
 ... and without the attribute keep, I get "WARNING:Xst:646 - Signal <unconnected1> is assigned but never used. This unconnected signal will be trimmed during the optimization process." in addition to the usual warnings - and with the attribute keep, I get:
WARNING:Xst:1580 - Signal  with a "KEEP" property is assigned but never used. Related logic will not be removed.
AAAAHH!!! I know, I put it there myself ! :/ Is there any way to keep the sythesizer happy about this kind of situation? (on the good side, at least now I get only one warning to wade through, instead of multiple ones). Maybe there exists "attribute ignore WARNING:Xst:XYZ" :) ?
Expert Contributor
gszakacs
Re: WARNING:Xst:2677 and explicitly unconnected ports in Verilog (alternative to VHDL OPEN)?
I see you've pretty much answered your own questions.
Some notes:
XST does not "barf" with the unconnected port, it's only a warning.  XST gives the same
warning about unconnected ports in VHDL even when you use the "open" keyword.
You can filter warnings in the GUI, either individual instances of warnings, like
Or classes of warnings, like XST:2677.
Using KEEP attributes will help you see how much logic you've defined so far in an
unfinished project, but can cause DRC errors in bitgen if you don't get rid of them
in the final version you will load into the hardware.
-- Gabor
-- Gabor
Regular Visitor
sdaau
0
Thanks for the answer, @ !
Sorry about the use of "barf" - I intended it to mean just "outputs a message not to my liking" :) (didn't intend that to mean error)
By the way, I just found this thread: WARNING:Xst:647 again - Xilinx User Community Forums, where the issue of filtering warning messages is discussed in more detail...  Just like there, I'd also wish for a pragma or an attribute to instruct the command line tools to filter warnings from source code (as it would be better documented) - but I'll have to live with the GUI filtering...
Many thanks for this note - I would have definitely missed this at a later stage....
Cheers!
Expert Contributor
rcingham
0
A feature that is available in the corresponding tool from a competing vendor is the ability to selectively change, for instance, certain classes of Warning to Info...
"If it don't work in simulation, it won't work on the board."
Expert Contributor
gszakacs
I should also mention that it is still possible to build a bitstream file even when there are
DRC errors.  You can turn off DRC in the bitgen options.  Generally the extra logic with no
loads on its outputs should not hurt the operation of the device.
-- Gabor
-- Gabor
Expert Contributor
bassman59
At least for VHDL, it shouldn't even be a warning. If the user is competent enough to use the open keyword on a port map, the tools should honor it and not bother with spurious warnings.
Yes, I do this for a living.
Regular Visitor
sdaau
0
Hi all,
I just wanted to note that what is a good workaround for me, turned out to be the use of the filtering messages XML file filter.filter as an argument to, say, xst - in that case, warning messages seem to be filtered also from the stdout and the *.syr text report... (more in WARNING:Xst:647 again - Xilinx User Community Forums)
Thanks for this note - intuitively, that is exactly what I would expect from an OPEN keyword: the associated logic is instantiated, so it counts toward resource usage; however, given its unconnected, it simply wouldn't (shouldn't) influence the operation of the device... Nice to see this confirmed.
Cheers!
