Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
zilehuma
0
signal is connected to multiple drivers.
I am writing a verilog code which runs ok and gives correct output but is not synthesizable i.e. it gives error "signal is connected to multiple drivers". I don't know where is am making mistake. Kindly help me out as early as possible. I am here pasting my code here.
module MixColumn2 (input [127:0] state, input clk, input rst, output reg [127:0] MixColumnState,output reg signal);
reg [31 : 0] col1, col2, col3, col4;
reg [31 : 0] col1_saveVal, col2_saveVal, col3_saveVal, col4_saveVal;
reg [31 : 0] col1_shifted, col2_shifted, col3_shifted, col4_shifted;
integer xor_val_col1, xor_val_col2, xor_val_col3, xor_val_col4;
reg [7:0] cycle_count;
reg [7:0]MSB_Save_1,MSB_Save_2,MSB_Save_3,MSB_Save_4;
always @ (clk)
if (!rst)
begin
col1 <= 0;
col2 <= 0;
col3 <= 0;
col4 <= 0;
cycle_count <= 0;
col1_saveVal <= 0;
col2_saveVal <= 0;
col3_saveVal <= 0;
col4_saveVal <= 0;
col1_shifted <= 0;
col2_shifted <= 0;
col3_shifted <= 0;
col4_shifted <= 0;
xor_val_col1 = 0;
xor_val_col2 = 0;
xor_val_col3 = 0;
xor_val_col4 = 0;
MixColumnState <= 0;
cycle_count <= 0;
signal <= 0;
end
else
begin
if (cycle_count == 0)
begin
col1 <= {state [127:120], state [95:88], state [63:56], state [31:24]} ;
col2 <= {state [119:112], state [87:80], state[55:48], state [23:16]};
col3 <= {state[111:104], state [79:72], state [47:40], state [15:8]};
col4 <= {state [103:96], state [71:64], state [39:32], state [7:0]};
end
else if(cycle_count == 5)
begin
MixColumnState[127:96] <= {col1_shifted [31 : 24],col2_shifted [31 : 24],col3_shifted [31 : 24],col4_shifted [31 : 24]} ;
MixColumnState[95:64] <= {col1_shifted [23 : 16],col2_shifted [23 : 16],col3_shifted [23 : 16],col4_shifted [23 : 16]} ;
MixColumnState[63:32] <= {col1_shifted [15 : 8],col2_shifted [15 : 8],col3_shifted [15 : 8],col4_shifted [15 : 8]} ;
MixColumnState[31:0] <= {col1_shifted [7 : 0],col2_shifted [7 : 0],col3_shifted [7 : 0],col4_shifted [7 : 0]} ;
signal <= 1;
end
else
begin
col1 <= col1 << 8;
col2 <= col2 << 8;
col3 <= col3 << 8;
col4 <= col4 << 8;
// Shifting values for adding next time
col1_shifted [31 : 24] <= col1_saveVal [23 : 16];
col1_shifted [23 : 16] <= col1_saveVal [15 : 8];
col1_shifted [15 : 8] <= col1_saveVal [7 : 0];
col1_shifted [7 : 0] <= col1_saveVal [31 : 24];
col2_shifted [31 : 24] <= col2_saveVal [23 : 16];
col2_shifted [23 : 16] <= col2_saveVal [15 : 8];
col2_shifted [15 : 8] <= col2_saveVal [7 : 0];
col2_shifted [7 : 0] <= col2_saveVal [31 : 24];
col3_shifted [31 : 24] <= col3_saveVal [23 : 16];
col3_shifted [23 : 16] <= col3_saveVal [15 : 8];
col3_shifted [15 : 8] <= col3_saveVal [7 : 0];
col3_shifted [7 : 0] <= col3_saveVal [31 : 24];
col4_shifted [31 : 24] <= col4_saveVal [23 : 16];
col4_shifted [23 : 16] <= col4_saveVal [15 : 8];
col4_shifted [15 : 8] <= col4_saveVal [7 : 0];
col4_shifted [7 : 0] <= col4_saveVal [31 : 24];
end
cycle_count <= cycle_count + 1;
end
always @(xor_val_col1, xor_val_col2, xor_val_col2, col1_shifted, col2_shifted, col3_shifted, col4_shifted )
begin
xor_val_col1 = 0;
xor_val_col2 = 0;
xor_val_col3 = 0;
xor_val_col4 = 0;
if (col1 [31] == 1)
xor_val_col1 = 8'b 00011011;
if (col2 [31] == 1)
xor_val_col2 = 8'b 00011011;
if (col3 [31] == 1)
xor_val_col3 = 8'b 00011011;
if (col4 [31] == 1)
xor_val_col4 = 8'b 00011011;
// main processing
MSB_Save_1 = (col1 [31 : 24] * 2) ^ xor_val_col1;
col1_saveVal [31:24] = MSB_Save_1 ^ col1_shifted [31:24]; // 02
col1_saveVal [23:16] = col1 [31 : 24] ^ col1_shifted [23 : 16]; // 01
col1_saveVal [15:8] = col1 [31 : 24] ^ col1_shifted [15 : 8]; // 01
col1_saveVal [7:0] = MSB_Save_1 ^ col1 [31:24] ^ col1_shifted [7 : 0]; //03 b1 xor bf xor b3
MSB_Save_2 = (col2 [31 : 24] * 2) ^ xor_val_col2;
col2_saveVal [31:24] = MSB_Save_2 ^ col2_shifted [31:24];
col2_saveVal [23:16] = col2 [31 : 24] ^ col2_shifted [23 : 16];
col2_saveVal [15:8] = col2 [31 : 24] ^ col2_shifted [15 : 8];
col2_saveVal [7:0] = MSB_Save_2 ^ col2 [31:24]^ col2_shifted [7 : 0];
MSB_Save_3 = (col3 [31 : 24] * 2) ^ xor_val_col3 ;
col3_saveVal [31:24] = MSB_Save_3 ^ col3_shifted [31:24];
col3_saveVal [23:16] = col3 [31 : 24] ^ col3_shifted [23 : 16];
col3_saveVal [15:8] = col3 [31 : 24] ^ col3_shifted [15 : 8];
col3_saveVal [7:0] = MSB_Save_3 ^ col3 [31:24]^ col3_shifted [7 : 0];
MSB_Save_4 = (col4 [31 : 24] * 2) ^ xor_val_col4;
col4_saveVal [31:24] = MSB_Save_4 ^ col4_shifted [31:24];
col4_saveVal [23:16] = col4 [31 : 24] ^ col4_shifted [23 : 16];
col4_saveVal [15:8] = col4 [31 : 24] ^ col4_shifted [15 : 8];
col4_saveVal [7:0] = MSB_Save_4 ^ col4 [31:24] ^ col4_shifted [7 : 0];
end
endmodule
The error shows...
ERROR:Xst:528 - Multi-source in Unit <MixColumn2> on signal <col4_saveVal<26>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <MixColumn2> on signal <col4_saveVal<25>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <MixColumn2> on signal <col4_saveVal<24>>; this signal is connected to multiple drivers.
In this way for all the indexes of col1_saveVal, col2_saveVal, col3_saveVal, col4_saveVal. Waiting for your quick response.
zilehuma
0
Re: signal is connected to multiple drivers.
I have detected the problem myself. Synthesis was successful when i removed the reset logic, i.e. assigning zero to all registers upon reset, and that was the only place where col1saveVal was being reassigned.
But here my question is that now what should i do for the reset?  If i remove the reset logic, the registers will give unknown value. Now can any one tell me a good solution.
mcgett
0
The problem is that you are assign the col1_saveVal, col2_saveVal, col3_saveVal and col4_saveVal in two different processes and you cannot do this.
You have two processes one sequential, note: this should be @ (posedge clk), and another combinatorial.  You are trying to reset the col#_saveVal in the sequential process, but since these are defined as a combinatorial function it is a conflict.
Get rid of the attempt to reset these values because it is unnecessary.
Have you tried typing your question into Google? If not you should before posting.
zilehuma
0
yes, as i stated earlier, the problem gets solved if i remove the reset logic, but then what should i do for reseting the registers?  as not reseting the registers result in unknown values (x).
zilehuma
0
oh the problem is solved. Thank you.
Expert Contributor
rcingham
0
It might help others if you post the working version.
zohair01
0
Put them all in the same block. The rest as well as your system logic. Actually you're using two different types of assignment, non-blocking and blocking, on the same registers. This is not good practice. You should only use one type for each signal.
