- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
synthesis/ MAP/PAR can run on different pcs at a time?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-14-2012 03:18 AM
Hello.
I need to reduce time spend in syntessi, map and PAR.
I have a quiestion:
synthesis/MAP/PAR can run on different pcs at a time? is this possible?
Re: synthesis/ MAP/PAR can run on different pcs at a time?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-14-2012 07:01 PM
It's not clear what exactly you are trying to do. Synthesis, map and par must happen in sequence as one step requires result files from previous step. You can have multiple PCs to implement the same design with different tool options.
soto1980 wrote:
Hello.
I have a quiestion:
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 03:15 AM
"If it don't work in simulation, it won't work on the board."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 09:05 AM
sorry, you're right, my question is unclear.
I know that the synthesis, mapping and PAR are sequential.
also know how to activate the mapping and PAR to use the availables cores on my pc.
But i am interested to know if is possible to use multiple pcs to implementthe same design.
if true, could you clarify how .
thanks for answering
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-16-2012 02:27 AM
You would be able to do multiple runs with different tool options in parallel. You could take the source files from a common network location, but will need separate .XISE/.GISE files and separate areas for results files.
