- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Fifo Generator SNAFU with First-Word -Fall-Thro ugh.
[ Edited ]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-27-2011 05:53 AM - edited 06-27-2011 06:00 AM
I have just changed an asynchronous FIFO produced by Fifo Generator 6.2 from 'Standard' to FWFT, and the result gives me a very rude simulation message (ModelSim PE 6.5f, as it happens):
# ** Failure: DRC Error : The attribute ALMOST_EMPTY_OFFSET on AFIFO36_INTERNAL is set to 8. It must be set to a value greater than (4 * roundup (WRCLK frequency / RDCLK frequency)) when AFIFO36_INTERNAL is configured in FIRST_WORD_FALL_THROUGH mode. # Time: 120500 ps Iteration: 2 Process: /asterix_tb/video_fifo/bu2_u0_gbiv5_bi_v5_fifo_fblk_gextw_4_inst_extd_gonep_inst_prim_gfn72_sngfifo3 6/fifo36_exp_inst/safe_mode/prcs_read File: C:/Xilinx12.3/ISE_DS/ISE/vhdl/src/unisims/primitiv e/AFIFO36_INTERNAL.vhd # Break in Process prcs_read at C:/Xilinx12.3/ISE_DS/ISE/vhdl/src/unisims/primitiv e/AFIFO36_INTERNAL.vhd line 879 # Simulation Breakpoint: Break in Process prcs_read at C:/Xilinx12.3/ISE_DS/ISE/vhdl/src/unisims/primitiv e/AFIFO36_INTERNAL.vhd line 879
The XCO file is:
############################################################## # # Xilinx Core Generator version 12.3 # Date: Mon Jun 27 12:39:59 2011 # ################################################## ############ # # This file contains the customisation parameters for a # Xilinx CORE Generator IP GUI. It is strongly recommended # that you do not manually alter this file as it may cause # unexpected and unsupported behavior. # ################################################## ############ # # BEGIN Project Options SET addpads = false SET asysymbol = true SET busformat = BusFormatAngleBracketNotRipped SET createndf = false SET designentry = VHDL SET device = xc5vfx100t SET devicefamily = virtex5 SET flowvendor = Other SET formalverification = false SET foundationsym = false SET implementationfiletype = Ngc SET package = ff1136 SET removerpms = false SET simulationfiles = Structural SET speedgrade = -1 SET verilogsim = false SET vhdlsim = true # END Project Options # BEGIN Select SELECT Fifo_Generator family Xilinx,_Inc. 6.2 # END Select # BEGIN Parameters CSET almost_empty_flag=false CSET almost_full_flag=false CSET component_name=async_fifo_8kx13 CSET data_count=false CSET data_count_width=13 CSET disable_timing_violations=true CSET dout_reset_value=0 CSET empty_threshold_assert_value=8 CSET empty_threshold_negate_value=9 CSET enable_ecc=false CSET enable_int_clk=false CSET enable_reset_synchronization=true CSET fifo_implementation=Independent_Clocks_Builtin_FIF O CSET full_flags_reset_value=0 CSET full_threshold_assert_value=8190 CSET full_threshold_negate_value=8189 CSET inject_dbit_error=false CSET inject_sbit_error=false CSET input_data_width=13 CSET input_depth=8192 CSET output_data_width=13 CSET output_depth=8192 CSET overflow_flag=true CSET overflow_sense=Active_High CSET performance_options=First_Word_Fall_Through CSET programmable_empty_type=No_Programmable_Empty_Thre shold CSET programmable_full_type=No_Programmable_Full_Thresh old CSET read_clock_frequency=125 CSET read_data_count=false CSET read_data_count_width=13 CSET reset_pin=true CSET reset_type=Asynchronous_Reset CSET underflow_flag=false CSET underflow_sense=Active_High CSET use_dout_reset=false CSET use_embedded_registers=false CSET use_extra_logic=false CSET valid_flag=true CSET valid_sense=Active_High CSET write_acknowledge_flag=false CSET write_acknowledge_sense=Active_High CSET write_clock_frequency=160 CSET write_data_count=false CSET write_data_count_width=13 # END Parameters GENERATE # CRC: 82072f02
I will now try to find a work-around...
EDIT: The other thing I changed was to swap the Read and Write clock frequencies, as I realise I had got them the wrong way round before.
Question: As the writing is actually always done at an effective 10MHz due to 'wr_en' being a 1-in-16 strobe, should I set "write_clock_frequency=10" instead, which will make the problem magically disappear?
Re: Fifo Generator SNAFU with First-Word -Fall-Thro ugh.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-27-2011 06:29 AM
