- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem resetting RAM block from core generator
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 11:16 AM - edited 03-08-2012 11:17 AM
I made this ram block with the RSTA connection and the ENA enabled all the time. I also added a *.COE file to fill the memory with initial values.
The reading, writing all works fine, but as soon as i reset the block, at first the DOUTA goes to "000...0" and after that it yust takes the previous values again instead of the initial values in the *.COE file.
for ex initial values => 01234567, 89ABCDEF; i read them and overwrite them with => 45645645, FFFFFFFF;
after resetting the content is => 45645645, FFFFFFFF;
instead of my expected => 01234567, 89ABCDEF;
Am i doing something wrong here? did i forget some signal that needs to be set aswell except the RSTA and ENA?
thx
Re: Problem resetting RAM block from core generator
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 11:28 AM
k,
The BRAM has no global reset (set every value to zero). One may only reset the output register.
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 11:29 AM
k,
How did the ram get implemented?
If one uses DFF in the CLB's, one can reset everything...but that uses a great desal of resources and logic.
Principal Engineer
Xilinx San Jose
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 12:46 PM - edited 03-08-2012 12:49 PM
this makes things different... so there is no way if i reset the memory block it sets its content back to the initial.COE file?
I adjusted my project using these gererated RAM blocks to save more space on my chip since i was working with 4 Sboxes (used for encryption) each contain 255 values of each 32bit wide.
my original design was this:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity SBox0 is
Port ( Clk : in STD_LOGIC;
Reset : in STD_LOGIC;
Write_Enable : in STD_LOGIC;
SAddr : in STD_LOGIC_VECTOR (7 downto 0);
SOut : out STD_LOGIC_VECTOR (31 downto 0);
SNewData : in STD_LOGIC_VECTOR (63 downto 0));
end SBox0;
architecture Behavioral of SBox0 is
type ram_t is array (0 to 255) of std_logic_vector(31 downto 0); -- Declaration of the RAM array signal Sram : ram_t;
begin
process (clk, Reset, Write_enable, SNewdata, SRam, SAddr)
begin
if (clk'event and clk = '1') then
if (Reset = '1') then
SRam <=( x"d1310ba6", x"98dfb5ac", x"2ffd72db", x"d01adfb7",
x"b8e1afed", x"6a267e96", x"ba7c9045", x"f12c7f99",
x"24a19947", x"b3916cf7", x"0801f2e2", x"858efc16",
..........................total of 255 values......................);
else
if (Write_Enable = '1') then
SRam(to_integer(unsigned(SAddr))) <= SNewData(63 downto 32);
SRam(to_integer(unsigned(SAddr + 1))) <= SNewData(31 downto 0);
else
SRam <= SRam;
end if;
end if;
else
SRam <= SRam;
end if;
end process;
SOut <= SRam(to_integer(unsigned(SAddr)));
end Behavioral;
i was working with an array that had my initial values. after synthesis i saw that i had
used available Number of Slice Registers 33916 301440 11% Number of Slice LUTs 45892 150720 30% Number of fully used LUT-FF pairs 33716 46092 73% Number of bonded IOBs 0 600 0% Number of BUFG/BUFGCTRLs 1 32 3%
With the coregenerator i only have:
used available
Number of Slice Registers 844 301440 0% Number of Slice LUTs 3238 150720 2% Number of fully used LUT-FF pairs 827 3255 25% Number of bonded IOBs 195 600 32% Number of Block RAM/FIFO 2 416 0% Number of BUFG/BUFGCTRLs 2 32 6%
for some reason this code window messus up my spacing sorry
The only upside i can think of to fix this problem is that the initial.COE file data contains the HEX values of the digits of PI
Would it be easyer if i generate these values on the fly and refill my Sboxes when needed? I only need to do this if my MasterKey changes (so thats not very often).
thank you for replying,
Sorry for my english it's not my main language and sorry for the messy VHDL code, i'm still new to this (programming in VHDL)!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 02:10 PM
I don't know how much block RAM you have left, but you could always have another RAM implemented
as ROM (never written after config) and just copy its contents to the working RAM when you need to
get back the .COE values.
-- Gabor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 03:23 PM
Doest that take like double of my chip again cause I have to make 8 RAM blocks now instead of 4?
The chip usage really doesn't bother me that much, but I guess the jury that reads my paper won't like it.
I'am yust trying to find the most cost efficient method of implementing what i need.
thx for the help so far poeple i appericiate it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 03:27 PM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 04:51 PM
kahosl wrote:
oh i get what u mean u want me to make 8 RAM blocks with the coregen? And it will still take less space then when i make the RAM with array's in VHDL myself?
The amount of space it'll take might depend on your BRAM's geometry. For example, if you're currently only using the lower half of an 18K BRAM, or half of the 36-bit width, you could store the 'original' copy of the data in the upper half of the address or data space and you wouldn't use any more BRAMs.
If you don't mind the whole design being reset, you could also trigger an FPGA reconfiguration, which will load the design and the original BRAM contents back from your configuration PROM.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 05:14 PM
thank you for the help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2012 05:21 PM
