- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ISE 13.1 corruption in PCF file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-17-2011 09:57 AM
I am getting a corrupted PCF file.
ERROR:ConstraintSystem:300 - In file: p25_top.pcf(98210): Unexpected end of file '.\p25_top.pcf' during read.
ERROR:Par:51 - The .pcf file contains errors. PAR cannot proceed.
Process "Place & Route" failed
From line 98210:
TIMEGRP P^Z<8f>^P = PIN
"p25_i/clock_generator_0/clock_generator_0/MMCM0_I
TIMEGRP ðlØ^L = PIN
TIMEGRP àòØ^L = PIN
Many other TIMEGRP's in the file have garbage names. The April update to 13.1 is installed.
Is there a fix available?
Stacey
Re: ISE 13.1 corruption in PCF file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-17-2011 10:59 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-07-2011 06:42 PM
I am having the same problem as above but am unsure what exactly to change the offending line to. Below is a snippet of the offending section of the pcf:
PIN
U_ila_pro_0/U0/I_YES_D.U_ILA/U_CAPSTOR/I_CASE1.I_Y ES_TB.U_TRACE_BUFFER/U_RAM/I_V5.U_CS_BRAM_CASCADE_ V5/I_DEPTH_LTEQ_32K.U_SBRAM_0/I_B36KGT0.G_RAMB36[3 ].u_ramb36/U_RAMB36_pins<63>
= BEL
"U_ila_pro_0/U0/I_YES_D.U_ILA/U_CAPSTOR/I_CASE1.I_ YES_TB.U_TRACE_BUFFER/U_RAM/I_V5.U_CS_BRAM_CASCADE _V5/I_DEPTH_LTEQ_32K.U_SBRAM_0/I_B36KGT0.G_RAMB36[ 3].u_ramb36/U_RAMB36"
PINNAME CLKAU;
TIMEGRP Xw«K = BEL
"U_ila_pro_0/U0/I_YES_D.U_ILA/U_G2_SQ.U_CAPCTRL/I_ SRLT_NE_1.U_SCE/I_YESLUT6.U_SRLC16E"
BEL
"U_ila_pro_0/U0/I_YES_D.U_ILA/U_G2_SQ.U_CAPCTRL/I_ SRLT_NE_1.U_WCE/I_YESLUT6.U_SRLC16E"
What should this TIMEGRP line be changed to?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-08-2011 07:10 AM
Same problem here.
How long will it be before the fix is available? Is there a better workaround because its impossible to guess what the corrupt line should be. At least give a hint on how to reconstruct the lines. Can I remove the offending lines?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-08-2011 08:43 AM
Two possible ways to work around this problem:
1. Turn off the global_opt option before running MAP if this switch is ON
2. Edit the .pcf file after MAP and before PAR and correct the constraint syntax at the line specified in error message, using BEL info at the right side of the equal sign may point out what the original group name should be
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-02-2011 12:57 PM
could you indicate what and how much the loss would be if global_opt is turned off?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-04-2011 03:23 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-04-2011 03:50 PM
I wasted huge amounts of time with 13.1 crashes and file corruption with global optimization enabled (not to mention wasted time actually watching global optimization run when it isn't crashing) and haven't noticed any area/speed/timing issues in my project with it disabled.
I've since upgraded to EDK 13.2 and haven't attempted to turn it back on since everything is running fairly smoothly without it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-31-2011 11:57 AM
13.3 is now out. Has the pcf corruption problem been fixed? It not, when will it be?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-31-2011 06:18 PM
The issue hasn't been fixed in 13.3 yet. It's still under investigation.
In previous test cases which demonstrate this problem, it only occurs in Windows system. Same design in Linux writes out normal PCF.
