Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
shreyassg13@gmail.com
0
Maximum frequency
Hello All,
I have written two codes, both for the same functionality. But the newer one is different than the older, in that one of the modules has been modified and an other module has been removed. The newer code is written so that it consumes lesser area compared to the older code. The maximum frequency that can be used as visible in the log for the newer code is a little higher than that for the older one.
Can anyone please let me know the reasons for this? And is this better or worse?
chrisz
0
Re: Maximum frequency
Is the frequency comparison from the XST report or the timing report?
Chris
Expert Contributor
sushantm
0
chrisz wrote:Is the frequency comparison from the XST report or the timing report?
shreyassg13,
Please answer this question.
Provide a bit more detail to help you better/answer your query!.
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
