Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
james.o.clay@lmco.com
0
Accepted Solution
Unwanted derived clock constraints
I have two different clocks that are derived, via a DCM, from a single clock.  Thus, the ISE tools "know" their relative frequencies and phases.  There are a few signals that cross from one clock domain to another and, for reasons that I don't want to get into, it doesn't matter how long it takes for the signals to get from one register to another.
The problem is that I get timing errors because one of the derived clocks is 60 MHz and the other is 100 MHz, so I guess the math works out that the worst case clock offset is 3.33 ns.  I have tried setting TIG's for the nets in question but they don't seem to help- perhaps because the problematic timing constraints are not in my UCF file, they are embedded in the tools and/or the CoreGen DCM.
How can I tell the tools to ignore the cross-over between clock domains?  I can, if need be, use separate clocks and DCM's to generate the two clocks that I need, but I would rather not do that for power consumption reasons (assuming once DCM uses less power than two).
Thanks for your help.
Expert Contributor
gszakacs
0
Re: Unwanted derived clock constraints
The normal way to handle cross-clock-domain paths is to define a
time group for each clock net and then use TIG constraints or
FROM : TO time constraints with an easily achievable setting.
For example:
NET "derived_60M_clk" TNM_NET = clk_60M_grp ;
NET "derived_100M_clk" TNM_NET = clk_100M_grp ;
TS_Ignore_60M_to_100M = FROM clk_60M_grp TO clk_100M_grp 16 ns DATAPATHONLY;
TS_Ignore_100M_to_60M = FROM clk_100M_grp TO clk_60M_grp 16 ns DATAPATHONLY;
The "derived_xxx_clk" names should match your global clock net names on the output of the DCM.
-- Gabor
-- Gabor
Regular Visitor
0
Thanks, I'll try that.
Regular Visitor
0
Just wanted to record for posterity's sake that this didn't work, though I still appreciate the suggestion.  I apologize that I didn't record the error message.  It was something about the FROM/TO constraint only applying to design:net, design:pin, and something else.  I thought that meant that I got the net names wrong, but I tried various names that should have worked, including wildcards and using the exact net names in the derived constraints in the Constraints Editor.
I then took the path of least resistance and used two DCMs and two different source clocks to produce the two clocks.  Hopefully this won't be much of a power hit.
