- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Warning:No Top-level Input clock for the design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-01-2011 08:17 PM
In my design ,when adding chipscope to my design ,compiling will appear this problem:
ERROR: 1 constraint not met.
PAR could not meet all timing constraints. A bitstream will not be generated.
To disable the PAR timing check:
1> Disable the "Treat timing closure failure as error" option from the Project Options dialog in XPS.
OR
2> Type following at the XPS prompt:
XPS% xset enable_par_timing_error 0
make: *** [implementation/system.bit] 错误 1
Done!
WARNING:EDK:1954 - No Top-level Input clock for the design.
Deleting the chipscope ,this problem is disappeared.But still exist the WARNING.
I want to know why ,how can I solve this problem?
Thanks for your replay!
Re: Warning:No Top-level Input clock for the design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-01-2011 09:10 PM
It seems you setup and hold timings are not close hence dosent meet.
There is a option in XPS settings by default it is enable you have to disable to"treat timing closure as an error".
Then it will not show the error but can may give the warning.
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-04-2011 04:39 AM
Which version of ISE/XPS you are using?
Check the timing report (.twx) in the implementation folder.
Do you get the WARNING:EDK:1954 - No Top-level Input clock for the design. only with chipscope added or in both cases?
