- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
What does maximum frequency in slog report mean?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2012 12:12 AM
Hello All,
I have written a verilog code which says that my maximum frequency is around 17 MHz. But I have used the same code with an onboard clock of 50 MHz and it worked fine. So what does this mean? Are we not supposed to use higher frequency than the one in log report or sometimes it works with higher frequency? Any suggestions would be helpful.
And one more thing: the log report said maximum frequency of 17 MHz but in my code I am generating 150 MHz using DCM and 50 MHz on board clock. And it worked fine. Please throe some light on as to what should be the clock used while implementing on hardware?
Re: What does maximum frequency in slog report mean?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2012 03:54 AM
"If it don't work in simulation, it won't work on the board."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2012 09:45 AM
When I generate the programming file, in the console I see the term maximum frequency. It is under final report, clock information. Is there any other place where I should look for it?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-30-2012 03:52 AM
Have you set any timing (period/frequency) constraints?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2012 01:57 AM
I have attached the report because it is too long to fit here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2012 03:40 AM
http://forums.xilinx.com/t5/Synthesis/Synthesis-Ti
So, it doesn't really mean anything, and should be ignored.
Meaningful timing information is output by the TRCE programme ("Generate Post-Place & Route Static Timing").
Look in the .TWR file for its output, or click the 'Timing Report' link in PN.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-02-2012 12:34 PM
In the timing report, what should I search for? I see
Clock to Setup on destination clock clk
| Src:Rise| Src:Fall| Src:Rise| Src:Fall|
Source Clock |Dest:Rise|Dest:Rise|Dest:Fall|Dest:Fall|
clk | 59.124| | | |
Is that it? even then it is 59.124 ns or 16.9MHz. But I have used a higher frequency and it worked.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-06-2012 04:17 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-07-2012 10:53 AM
I dont know what u r talking about. I have not set any constraint. Where can I know about these settings or constraints you told?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-08-2012 01:46 AM
Read The Fine Constraints Guide (usually cgd.pdf), looking for the section on PERIOD constraints.
As it's POETSday today, I'm in a good mood, so here's an example:
NET "clk32" TNM_NET = clk32;
TIMESPEC TS_clk32 = PERIOD "clk32" 31.25 ns HIGH 50%;
