Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
assaf_malki
0
Accepted Solution
Frequency Synthesizer for SFP/SMA GTP/GTX Transceiver Clocking
[ Edited ]
Hey guys,
I'm using Virtex-5 ML507.
I'm trying to use the Frequency Synthesizer (ICS843001-21) which is on board.
I've configured the DIP switches (SW6) according to the User Guide to produce a 155.52 MHz clock (for example).
According to the user guide, when J54 is shunted, the clock is driven out to the SMA connectors, J12 and J13, I can also see it in the schematic.
However, I use the scope, I've connected it to the J12 connector and I see nothing.
Am I missing something?
Thanks a lot.
Assaf.
alaney
0
Re: Frequency Synthesizer for SFP/SMA GTP/GTX Transceiver Clocking
You need to add a 100R termination across the diffrential pair to see an output.
Super Contributor
assaf_malki
0
Ok,
So when I connect it to the SMA_DIFF_CLK_IN in J10 connector which from my understanding, is the dedicated input clock to GTX_X0Y5, it uses it without a problem, right?
Another thing, I want to work with a speed of 1.6 Gbps, for that I need a clock of 80 Mhz, ICS843001-21 can't give me that clock according to the user guide, is there a way to work around it without using GREFCLK?
Can I config ICS843001-21 to give me that clock?
Thanks a lot.
Assaf.
mcgett
0
The SMAs are driven from a ICS85401 device with LVDS outputs.  While a 100 ohm termination would present a cleaner eye on the scope it is not necessary.  The absence of any signal, with the jumper on J54, would indicate that that something else is wrong.
Have you tried typing your question into Google? If not you should before posting.
Super Contributor
assaf_malki
0
That's wierd.
All I need to do is to turn on the ML507 and setup SW6 (and put the J54 jumper on), right?
Thanks a lot.
Assaf.
Super Contributor
assaf_malki
0
Ok,
I can see the clock, the connection with the scope was wrong.
Thanks a lot.
Assaf.
Super Contributor
assaf_malki
0
Well, I figured out a way to get that 80 Mhz clock.
I use 25 Mhz clock with M = 32 and N = 10.
The problem is that I take VCO all the way to 800 Mhz, is that ok?
Thanks a lot.
Assaf.
mcgett
0
According to the ICS843001 datasheet a VCO of 800 MHz is outside of the operating range of the device.
