Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
mehta.vishal.360
0
How to use two uarts in virtex 2 pro
Hello  all,
I have to make one application which uses two UARTS so i added uart_lite given in IP catalog and then make the TX and RX of the IP external. I have made max3232 circuit which works at 3.3 volts and i am connecting the TX and RX with max3232 11th and 12th pin which is TX and RX. I wrote the C code in which i am constantly sending "a" but am recieving some junk data on the terminal. I did check if the baud rate kept was diff but it was the same i reduced the baud rate than also the same thing...
Am i going wrong somewhere.???
Any help would be appreciated ..
mehta.vishal.360
0
Re: How to use two uarts in virtex 2 pro
I got the output  correct now......
But i had to keep the baud rate at the pc end lower than the baud rate at the FPGA side....this thing i did not understand....
Expert Contributor
rcingham
0
Perhaps the clock to the UART in the FPGA is less than it is expecting.
"If it don't work in simulation, it won't work on the board."
mehta.vishal.360
0
May be yes..but i did try it again and this time the baud rate kept was same and it worked properly so may be i might have mistaken the first time....
