- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Pin assignment between Virtex6 and DDR3
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-31-2010 08:06 AM - edited 12-31-2010 08:09 AM
Should I use Planahead or just assign pin continuously in a bank of Virtex 6 to connect with DDR3?
Re: Pin assignment between Virtex6 and DDR3
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-01-2011 03:43 AM
Well, are you using an existing board or are you designing a PCB?
Adrian
Signature:
1. Google your question before asking it.
2. If Google doesn't find a solution, post your question in a detailed, comprehensive, and clear way.
3. If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-02-2011 06:39 PM
I recommend that you use the MIG tool found in CORE Generator (Memories & Storage Elements / Memory Interface Generators).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-18-2011 12:09 AM
I'd agree that using the MIG to generate the necessary files is the best solution. One of the outputs is a .ucf file which contains pin out data.
That's much easier than trying to do it manually within PlanAhead and it's more likely to work (and it's also a bit quicker).
You can then import the .csv file into PlanAhead and that will show you pictorially which banks etc are used.
You can also export this from PlanAhead as a .csv to Excel if required. Note that any additional PlanAhead import operations overwrite existing data so any mods (e.g.. another interface, more pins) have to be added manually either by hand within PlanAhead, or within Excel and re-imported.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-09-2011 07:33 PM
I use MIG generate DDR3 constrains file(ucf),but when verified this UCF,I encounted ERROR messages as follows.
This is the message format for resynchronization clock (BUFR) constraints:
ERROR: The BUFR Constraint for the FPGA column '1' is not provided
in the UCF or Constraint provided for this column is not valid.
Following is(are) valid BUFR constraints.
AJ41 - X0Y143.
AD36 - X0Y141.
AF36 - X0Y139.
AD37 - X0Y137.
Following is (are) valid BUFR constraints.
AT6 - X2Y143.
AT9 - X2Y141.
AV6 - X2Y139.
AW7 - X2Y137.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-12-2011 11:21 PM
This is an known issue and will be fixed in MIG3.8 (ISE13.2). You can ignore it.
