Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
subhaz2552
0
Problem with constraining IO standard
        I am using Xilinx ISE 10.1i web pack edition. My design requires that the IO standard of the pins coming in and out of FPGA should be of type LVCMOS 3.3 V.  I used PACE feature of Xilinx ISE to assign the IO standard. But whenever my logic drives a high, the output pins only reach 2.5 volts max. But whenever an input signal which is 3.3 volts is taken into FPGA and brought out it has a proper voltage value. I have not used any service pack. Can someone please suggest me a solution to this problem.
Thanks in advance
barriet
0
Re: Problem with constraining IO standard
You should likely be using service pack 3 for 10.1 (10.1.03);
http://www.xilinx.com/support/download/index.htm
But I wouldn't expect that to change this situation.
1) How did you measure the voltage (DVM, oscilloscope, etc.)?
2) Did you use the same I/O pin for the output in the 2 test cases?
3) What is the I/O voltage (Vcco) of the banks used for the outputs?
4) What is the load seen by the output, e.g. testpoint, another IC, pull-down resistor, some combination, etc.
The most common cause of this is using an output in a bank with a Vcco of 2.5V. The I/O standard of LVCMOS33 can't fix this.
bt
