Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
guetguet
0
Quickly clock in an architecture
Hello everyone,
I would like to know if it is possible to deduct a four times faster clock from  an input clock in an architecture. In fact I would like to use a clock for a process and a four times faster for an other.
Thanks a lot.
Expert Contributor
eteam00
0
Re: Quickly clock in an architecture
Yes, this is simple to implement, subject to datasheet limits for the target device.
There is a ClockGen Wizard in the Xilinx ISE toolset for generating the correctly configured clock generator primitive.
-- Bob Elkind
SIGNATURE:
Summary:
Expert Contributor
sushantm
0
which arcitecture you are targetting ?
You can use pll and dcm wizard to generate the desired clock.
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
