Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
drgowans
0
Virtex 5: DFS frequency range too restrictive for clkfx
[ Edited ]
I have a Virtex 5 FX200T -1 speed part.
I have a DCM setup to take in a 156 MHz clock on CLKIN, and through the CLKFX output a 93.6 MHz clock.
This is a multiply of 3, divide by 5.
What do I set DFS_FREQUENCY_MODE to? For low frequency DFS mode, the constraints on the CLKIN are too low.  For the high frequency DFS mode, the constraints on the CLKFX are too high.
I can't use CLKDV, because none of the divide values are appropriate.  I can't imagine having to cascade DCMs for this.
The data sheet says:
DFS Low frequency mode:
CLKIN :   1 - 140 MHz         -- BAD for my input clock of 156 MHz.
CLKFX :  32 - 140 MHz       -- Good for my output clock of ~94 MHz.
DFS high frequency mode:
CLKIN:  25 - 350 MHz        -- Good for my input clock of 156 MHz.
CLKFX: 140 - 350 MHz      -- BAD for my output clock of 94 MHz.
So which one should I use?  Or can I not actually do 3/5 of a 156 MHz clock with a Virtex 5 DCM?
Message Edited by drgowans on 04-08-2009 11:14 AM
Expert Contributor
gszakacs
Re: Virtex 5: DFS frequency range too restrictive for clkfx
If you don't need a specific relationship between edges of 156 MHz and 93.6 MHz, you could instead
generate 187.2 MHz in high frequency mode and use a fabric flip-flop to divide by 2.  This still only
uses one DCM, you don't need to waste a BUFG for the single flip-flop on the 187.2 MHz net but
you should add one on the flip-flop's Q output.
HTH,
Gabor
-- Gabor
drgowans
0
Thanks, that's helpful.  Any idea if it would cause any jitter issues, or in your experience would it be stable enough?  I am inclined to think it would be fine, but if anyone has experiences with this I'd be curious.
I am also wondering if I couldn't run the DCM in one mode or the other and just hope it works anyway, should I take the chance?
-Daniel
Expert Contributor
gszakacs
The fabric flip-flop should not add as much jitter as the DCM does.  If your 93.6 MHz clock is
sensitive to jitter, you may want to use a PLL instead.
-- Gabor
