Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
liejie04065136
0
Accepted Solution
about slave selectMAP configuration !!Need your heip!
My FPGA is virtex5,storage device is XCF128X,and i want to use the slave selectMAP configuration mode. I have read the platform flash XL configuration and storage device user guide! As the guide's figure2-1, i connect FPGA to XCF128X.
1)All the pins which need to be connected are appear in the figure,right?
2)The configuration interface pins which not appear in the figure ,such as D_IN,DXP,DXN,how to connect?
3) Can i use the JTAG mode in slave selectMAP configuration mode? If i want to acheive both JTAG configuration and slave selectMAP configuration mode in my design,what changes i need to do ?
liejie04065136
0
Re: about slave selectMAP configuration !!Need your heip!
I am waiting for your reply
mcgovern
0
The connection diagram is correct.
These are not used for Slave Selectmap. Consult the Virtex-5 config user guide - http://www.xilinx.com/support/documentation/user_guides/ug191.pdf
JTAG is independent from SelectMap and is always available regardless of teh Mode pin setting - you do not need to change the mode pins to access the device via JTAG. You simply need to connect your JTAG pins as per the User Guide - http://www.xilinx.com/support/documentation/user_guides/ug191.pdf.
liejie04065136
0
Thank you for your reply!
If the JTAG header is directiy connected to the FPGA's 4 pins:TMS TCK TDO TDI,  can i use the JTAG configuration mode?
gregmeredith
0
You can always use JTAG no matter what the mode pins are set to.
