- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
sine wave signal as clock input
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-28-2011 08:59 PM
In this particular design, I have a 10 MHz sine wave (from an atomic clock source) as my clock input to my Virtex 5. It's been working pretty well. The sine wave has a 1.4 V peak to peak and is centered around 1.2 V (e.g. it swings from 0.5V to 1.9V). I set the I/O standard for this input to be LVCMOS25. Today when I actually measured the VCCO pin for this bank with a voltmeter, I was very surprised to find out that I have been biasing it with 1.69 V instead of 2.5 V the entire time.
1. Since my design very much depends on this clock input and it has worked well despite this recently discovered "mistake", does this mean that the I/O bank accepted the incorrect biasing and operated the input pin at LVCMOS18 instead?
2. A follow up question is this: is it true that as long as my sine wave crosses VIH min (voltage-input-high minimum) but doesn't go above VIH max and also crosses VIL max but doesn't go below VIL min, the input buffer will be able to convert it to a square wave clock? Since this sine wave also satisfies these specifications for LVCMOS25 (VIH min = 1.7V, VIL max = 0.7V), I would still be able to use this sine wave signal as my clock if I actually CORRECTLY set the Vcco to 2.5V, right?
3. The reason that it's 1.69 V at the Vcco instead of 2.5 V is that I naively applied the bias by voltage-dividing a 3.3 V with a 100K and a 32K resistors. Before configuration, I do actually get around 2.5 V at the Vcco pin. But after configuration, the Vcco pin draws a lot more current and thus pulls down the voltage level. Now my two solutions are:
a. use lower-valued resistors such as 1k and 320 instead, or
b. get some voltage regulator, e.g. LDO, to supply the 2.5 V.
I know b is the safer bet but I want to avoid creating another power plane for 2.5 V since I already got a bunch for 3.3 V and 1.8 V
(just to be clear, I am not actually working directly with a V5 chip but instead designing a daughterboard for an Opal Kelly V5 development board that has expansion connectors for these I/O banks)
Re: sine wave signal as clock input
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-28-2011 09:56 PM - edited 06-28-2011 11:07 PM
I'll take these questions, one by one, with the understanding that I am not a Xilinx employee with 'inside' knowledge.
No. It means you are operating with LVCMOS25 IOSTANDARD (see the datasheet) and a 1.69V VCCO supply -- and you were violating the VIN(max) spec beyond which device reliability and longevity may be degraded. See DS202 Table 7.
Not necessarily. Depending on edge speeds, DC bias, and waveform symmetry, you may see some duty cycle distortion. You are also greatly susceptible to clock jitter due to the influences of noise combined with very slow (dangerously slow!) edges. You should consider a clock source with square wave output rather than sinewave.
Yes, subject to the same warnings as above. This would avoid the violation of the datasheet maximum input voltage.
Power plane vs. wide trace routing and voltage divider vs. active regulator are two independent decisions. The decision for circuit board routing will need to consider DC and peak supply current. Can you position 0402 or 0201 decoupling caps very close to the VCCO supply pins?
You are the engineer. It is up to you to do the math and make the tradeoffs. You can't ask strangers to make these decisions for you, especially without knowing more details than you can pack into a forum thread.
If you don't trust yourself to make the decision, call for help from someone who can help you on-site.
Also, if you look at your VCCO supply with an oscilloscope rather than a voltmeter, you will likely be shocked.
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-28-2011 11:17 PM
-- Bob Elkind
Bob, thanks again for your help!
I don't quite understand your answer to my first question. What do you mean by "violating VIN (max)"? Is VIN VIL or VIH? Can you elaborate on that?
I have to use this sine wave clock source because all the other equipments in my experiment are synchronized to this clock and my FPGA board is part of this experiment setup. I thought I read somewhere that the input buffer has built in schmit trigger in it?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-28-2011 11:55 PM
- DS202, Table 7. VIH max for LVCMOS25 is VCCO + 0.3V.
- Your VCCO is (measured by a voltmeter, which is inadequate method) 1.69V.
- Your input logic swing is 1.4V P-P centred about 1.2V, resulting in a VIH of 2.0V. This is near -- or possibly greater than -- 1.69V + 0.3V = 1.99V.
This doesn't make a 10MHz single-ended sinewave an optimal source clock signal. Each rising and falling edge is roughly 50nS duration, received by input buffers which are sensitive and gained-up enough to switch in a fraction of a nanosecond. If you are satisfied with performance and reliability, I won't argue with you.
I thought I read somewhere that the input buffer has built in schmitt trigger in it?
- I searched for 'schmitt' and 'hysteresis' in DS202, UG621, and UG190. No hits.
- Hysteresis implies a low-pass filter.
- You can implement a 2-pin hysteresis solution, using an output pin and a 2-resistor network.
- You can use an off-chip buffer to "square up" the sinewave
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 12:18 AM
How did you get a VIH of 2.0V? I thought VIH = 1.2 + 1.4/2 = 1.2 + 0.7 = 1.9 V, no?
About this 2-pin hystersis solution, are you talking about using an op-amp? Basically building a schmitt trigger?
Thanks!
-- Bob Elkind
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 05:06 AM
You can put a basic OPAMP in comparator mode to have a "numeric" clock... With a trigger you will have not have a 50% duty cycle if I well remember my courses.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 05:27 AM
2-pin hysteresis input
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 06:34 AM
Welcome to digital logic design from the 1970s.
slow edge inp signal ---\/\/---+--------->|->FPGA input buffer-----+----> to FPGA logic
R1 | R2 | |
+---\/\/---|<-FPGA output buffer <--+
The degree of hysteresis depends on the ratio of R1 to R2. You might try R1=1K, R2=10K to start.
Does this make sense?
-- Bob Elkind
Summary:
Why sleep is important
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 06:41 AM
I was over-tired and goofy, and instead of dividing 1.4 by 2 and adding to 1.2, I divided 1.2 by 2 and added to 1.4.
My bad. My math was wrong, but it seemed right at the time. You are correct.
-- Bob Elkind
Summary:
Re: Why sleep is important
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 03:05 PM
Something else to add to this discussion, yes you may be violating the LVCMOS25 specs from table 7 in DS202, however this is not the spec you should be looking at if you are concerned over damaging your device. It says specifically in table 7 the following:
"Values for VIL and VIH are recommended input voltages."
Table 7 VIH/VIL is for recommended values for different IO standards. This is not the absolute maximum that a given IO can handle. The absolute max you would look at VIN from table 1, which will depend on your imput voltage. So your absolute max would be 2.19 V (if Vcco < 2.5 V). Additionally, there are power and ground clamp diodes on the V-5 to provide for ESD protection that can help here as well.
