Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
vikxxxx
Re: Can't generate test pattern on Chrontel CH7301C DVI output device on ML505 board
I faced this problem before. In ML505 board, the pin AM9 is connected to the reset pin of the Chrontel chip. You need to drive this pin to 0 in your design.
If you are using EDK, add the following line to your .mhs file
PORT vga_reset_pin = sys_rst_s, DIR = O
Add these lines into your .ucf file
Net vga_reset_pin LOC = AM9;
Net vga_reset_pin IOSTANDARD = LVCMOS33;
NET vga_reset_pin TIG;
david.greaves
The earlier posting enabled DVI output (I think).  The following does VGA mode.
I fiddled around with various settings until the following worked for me.  This generates VGA output for data or built-in test patterns on the ML605 card.
        static void Main()
            I2C_master.i2c_chrontel_cmd(0x49, 0xC0); // DVI Off, VGA ON.
            I2C_master.i2c_chrontel_cmd(0x21, 0x09); // Enable H synch output + 1
            I2C_master.i2c_chrontel_cmd(0x22, 0x16); // Enable V synch output
            while(true)
               while(!checker)  Kiwi.Pause(); // nb: not debounced: so a bit weak!
               I2C_master.i2c_chrontel_cmd(0x48, 16+8+1);
               while(checker)  Kiwi.Pause();
               I2C_master.i2c_chrontel_cmd(0x48, 16+8+2);
               I2C_master.i2c_chrontel_cmd(0x48, 16+8+0); // Normal operation again.
I attach the source code in C# for our Kiwi compiler and also the generated verilog subsystem.
[I realise you wont want to use Kiwi but the C# is very readable!]
David Greaves
