Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
arash-rezaee
0
Accepted Solution
Configuration ML605 with Impact problem
Hi every one. I am using ISE 13.4 and Windows 7 (32 bit). I bought ML605 board and now I want to configure FPGA with iMPACT and Chipscop. When I open iMPACT software I choose "Configure device using boundary scan" and it started to scan for JTAG. When the searching finished, the warning appeared. The warning is : "WARNING :iMPACT:923 - cannot find the cable, check cable setup" . I Looked at device manager to see if the usb cable installed correctly or not. And it is fine. In device manager I have :"programming cable => Xilinx USB Cable ".
What should I do to correct this warning?
Arash
arash-rezaee
0
Re: Configuration ML605 with Impact problem
I am using ISE 13.3 Not 13.4. Sorry for mistake
arash-rezaee
0
Hi every one.
For those has this problem I found the solution.
refere to this link and follow the structure, then you can use USB JTAG
http://www.xilinx.com/support/answers/41442.htm
Arash
eshwaran
0
Thanks!!! It worked for me
