Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
solonor2011
0
Connecting ML605 with and without the connectivity kit
Hi everyone,
I have a question about connecting two ML605 over GTX running Aurora protocol (Xilinx example design). Here are the the configurations that I have tried:
1- Connect two ML605s using the GTX SMA connectors that are on the board. (5 GHz)
2- Connet two ML605S + XM104 Connectivity Kit (FMC) using SMA connectors that are on the FMC card (5 GHz)
3- Connet two ML605S + XM104 Connectivity Kit (FMC) using SATA connectors that are on the FMC card (3.125 GHz)
Let's first talk about cases 1 and 2. In both case the link comes up. In case 1, I can reliably run without any BER but in case 2 I get random bit errors. I have tried this with different combinations of 4 boards that I have, and, in case 2, only one combination could run without any errors. Case 1 is completely reliable for all the combinations.
Case 3, which is running slower (3.125 GHz), works reliably for all the boards.
My questions is that, should I expect a more unreliable connection when I'm using an FMC card? Does the extra connector cause signal integrity and bit error issues?
Amir
mcgett
0
Re: Connecting ML605 with and without the connectivity kit
Your case #2 will have more loss in the communication channel due to the FMC connectors and additional PCB trace on the modules.  Using different settings for the TX swing, TX pre-emphasis, and RX equalization will improve the BER for this link.
BTW, your line rates are actually Gbps and not GHz.
Have you tried typing your question into Google? If not you should before posting.
solonor2011
0
Thanks for the reply. That was my mistake, I meant Gbps not GHz.
Should I just increase the TX Swing (set to 810mv right now)?
Could you please give me some hints or point me to a document about how to set these three values for better signal integrity?
Amir
solonor2011
0
I increased the TX pre-emphasis (TXPREEMPHASIS set to 2.77) and also voltage swing (TXDIFFCTRL set to 1180mv) to max. I definitely get less errors but still errors are pretty frequent.
1- Are there any other parameters that I should tweak?
2- Should I also change TXPOSTEMPHASIS?
It seems that I should use IBERT to tune these parameters. Right?
Amir
mcgett
0
Yes, IBERT is the best way to optimize the link.
One other item to look at is the construction/length of the coax cables that you are using to ensure that there are no issues.
