- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Hot Spartan 6 SP605 FPGA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 09:01 AM
Hello!
A few days ago I'm working on a simple embedded system with MicroBlaze. All goes well the first 10 minutes, then the voltage regulators and the FPGA will become very hot.
My question is, is there a specific Fansink for this kit (SP605) and where I can get it?.
I searched on Radian heatsinks, but they say the BGA is quite small.
Diego H.
Re: Hot Spartan 6 SP605 FPGA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 09:09 AM
Diego,
What is "quite hot?"
As long as the die (junction) temperature is below 85C, you are OK (in specification).
Note that in still air the thermal die to case increase in temperature may be as much as 7 to 10 degrees C per watt.
What power is estimated for your design by XPA in the tools? What die temp is predicted?
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 09:31 AM
Junction temperature : 35.4 °C.
Total on chip power: 0.543W.
Thermal margin : 49.6 °C, 2.5W.
But the FPGA exceeds this temperature to about 60 ° C, measured with laboratory instrumentation.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 09:49 AM
Diego,
'First, you should find out why you are drawing so much current.
Is it IO? Is it the core?
Do you have the right clock frequency in the estimate?
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 10:18 AM
Yes, i have the 200MHz clock in the estimate, and I only use the UART, no ethernet, no system ACE, not FMC.
This also happens with the examples I have downloaded from the Xilinx web site, so I do not think it's a bad design made by me.
I think it's important to note that while the FPGA is not configured, the temperature is normal (less than 10°C), but the voltage regulator heat up after about 10 minutes.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 10:24 AM
OK, so the case temperature is 85C or so? That is very bad, as the die is perhaps 40C hotter.
You need some serious airflow, or heatsinking.
Yes.
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 10:32 AM
Yes, I really need a fansink. The problem is I can not find any who could use in my SP605, most are very large and do not correspond to the size of the FPGA.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 10:47 AM
I also had this problem with the Atlys and XUP-V5 boards, so I added a heatsink and fan:
I use this heatsink:
It's the RS components Code 104036
With this fan:
It's the RS components Code 191856
HTH,
best regards,
Pedro
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 11:00 AM
Thanks pmartos, I'll search for something closer to Mexico because I need the material as soon as possible.
Thank you.
