Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
0
IMPACT Read Status Register fails
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-29-2011 02:42 PM
I am using an ML605. I used Impact to erase the BPI flash device and do a blank check. Both succeeded.
When I attempt to do a "Read Device Status" under Impact, I get a red box message "ReadStatusRegister Failed"
The Flash device is a Numonyx P30.
The JTAG is operating at 3 Mhz (I reduced the TCK from 6 Mhz following some posts on the forum).
Any clues on how to overcome this ?
The impact log is as follows:
INFO:iMPACT - Current time: 9/29/11 5:35 PM
// *** BATCH CMD : ReadStatusRegister -p 2 -bpionly
Maximum TCK operating frequency for this device chain: 16700000.
Validating chain...
Boundary-scan chain validated successfully.
2: Device Temperature: Current Reading: 29.70 C, Min. Reading: 28.72 C, Max. Reading: 40.53 C
2: VCCINT Supply: Current Reading: 1.011 V, Min. Reading: 1.008 V, Max. Reading: 1.014 V
2: VCCAUX Supply: Current Reading: 2.502 V, Min. Reading: 2.496 V, Max. Reading: 2.508 V
'2': Read Status Register command is not supported for 28F256P30.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
RRS
0
Re: IMPACT Read Status Register fails
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-07-2011 06:39 AM
rahulrs84,
This post would be better served being moved to the Other Tools thread, as the issue appears in iMPACT, and is an iMPACT error.
However, I believe I can help answer this for you.
The problem here is you are trying to read the status register of the P30. ReadStatusRegister in iMPACT is intended to be used to read the status register of Xilinx FPGAs, not third party flash devices.
For more info on the Status Register, please see Answer Record 24024: http://www.xilinx.com/support/answers/24024.htm
