Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
stefan63
0
What programming cable included in CoolRunner™-II Starter Kit -?
Hi people,
I plane to buy "CoolRunner™-II Starter Kit " and i wonder - will be possible (in future ) with included cable to programm soldered devices on my board - CoolRunner or XC95xxx ?
Or i must buy other cable?
regards
sandrao
0
Re: What programming cable included in CoolRunner™-II Starter Kit -?
Hi ,
The cable that comes with the Coolrunner-II Starter board is just a USB cable. The programming ability is built into the board.
So if you have another board you will need another cable. You can find the info on the Xilinx cables here : http://www.xilinx.com/products/design_resources/config_sol/
Super Contributor
xilant
0
You sure ?!
to my knowledge there is onboard usb microcontroller that is NOT connected to the coolrunner JTAG pins, so I wonder how to built-in on board usb configuratio can be possible?
Antti Lukats
Expert Contributor
three.jax
0
The Cable is a USB to Mini-USB cable designed to be used with the Export Software (Provided).  You have the choice of using the provided USB cable or using any Standard JTAG interface as the Jtag Header is available also.
2 places to look for more info:
-Three.Jax
Super Contributor
xilant
0
reply to original poster:
NO the supplied cable can not be used.
you need separate JTAG cable.
stefan63
0
Re: I found circiut for cable, is it usable?
Thank You for answers!
So , starter kit is only fo starting.
Is this usable cable for JTAG programming?
Stefan
Expert Contributor
three.jax
0
The USB cable that is provided will only work with this board and no others.   If you want to access JTAG to program the part, you will need a seperate cable, such as the ones listed at:
I would suggest the Platform USB, or the Parallel Cable IV(Parallel port on your PC is required)
-Three.Jax
stefan63
0
Re:three.jax, how do You think - is this cable correct: http://elm-chan.org/works/avrx/xilinx.png ?
Super Contributor
xilant
0
to three.ajax
isnt the cable provided just plain standard USB cable?
so it works with any device that has standard USB connectors?
maybe i am mistaken
Antti Lukats
Expert Contributor
three.jax
0
It's a USB to Mini- USB Cable.  It matches the one that I have for my Digital Camera.
-Three.Jax
