取消
显示结果
搜索替代
您的意思是:
Visitor hxing
491 次查看
关于Timing Analysis 的问题
我今天看了 Analyzing Input Timing,如下面的 链接所讲:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_timing_analysis_input.htm
看了之后,不是很懂,列出了两个问题,如下面的 图片所示,烦请 大牛们 赐教,谢谢!
0 项奖励
5 条回复
432 次查看
回复: 关于Timing Analysis 的问题
1. slack旁边的等式就是计算公式: requirement - (data path - clock path - clock arrival + uncertainty)
或者点击slack数字上的超链接,会弹出计算公式的对话框,每一项对应的数值也有罗列。
2. 第一列为location,也就是路径所经由的物理实体;第二列为delay type,也就是延时类型,是器件的逻辑延时还是布线延时,或者是同步器件的建立/保持时间;第三列为Delay值,列出每一项对应的具体延时值。
以此路径为例,data path是从输入管脚一直到寄存器。D13.I为起点,表示管脚D13输入口;SLICE_X27Y52.BX为寄存器所在SLICE的数据输入口;SLICE_X27Y52.CLK为寄存器的时钟输入口。
大部分的时序参数Txxxx可以从ISE的安装路径获取描述:
e.g. C:\Xilinx\14.7\ISE_DS\ISE\doc\usenglish\help\delay_types\html\web_ds
Tiopi可查看ta_tiopi图示及描述,表示从管脚封装到input buffer输出的延时
Tdick可查看ta_tdick图示及描述,表示相对于CLK的建立/保持时间要求
424 次查看
( 大牛们 ) Big cow says…
You are seeing only the tail of the elephant and trying to understand the whole elephant. I am sorry to say that the old ISE software has very little documentation that will help you. However, Xilinx has created the Vivado software to replace ISE. Vivado documents will help answer your questions.
First, please note that your questions are from ISE document about “Input Timing”.   Input Timing is used to analyze “Source Synchronous Input” to the FPGA. Source Synchronous Input means that a device outside the FPGA is sending a clock and data to the FPGA.
First, I suggest you study basics of Timing Analysis found in Chapter 5 of Xilinx document UG906.   Then, I suggest you read about Constraining I/O Delay in Chapter 4 of Xilinx document UG903.   Please note that UG906 and UG903 are documents for the Vivado software. However, concepts of “Timing Analysis” and “Constraining I/O Delay” are similar for Vivado and ISE.
0 项奖励
Visitor hxing
286 次查看
Hi Sir,
  谢谢你的回复。
  对于第一个问题,我按照那个 公式计算,结果 跟 列出的不一样。
  公式是 requirement - (data path - clock path - clock arrival + uncertainty)
 但是图中给出了 requirment = 0.000ns
                data path = 1.379ns
                clock path = -0.443ns
                clock arrival = 0.000ns
                uncertainty = 0.135ns
 按照公式: 0 - (1.379 - (-0.443) - 0 + 0.135 = -1.957 ,这个不是 1.949ns。 请问 我哪里算错了吗?
  对于第二个问题,我再看看 相关的资料。
  再次感谢你的回复。
0 项奖励
Visitor hxing
282 次查看
Hi Sir,
  Thank you for your reply and suggestion!
  I will study these documents.
  Thanks again!
BR,
Hxing
0 项奖励
262 次查看
@hxing  已写:
Hi Sir,
  谢谢你的回复。
                data path = 1.379ns
  对于第二个问题,我再看看 相关的资料。
  再次感谢你的回复。
Destination Clock: DCM1_CLK0 rising at 3.906ns
clock arrival应为3.906ns。
0 项奖励
