取消
显示结果
搜索替代
您的意思是:
266 次查看
注册日期: ‎10-09-2019
1 关于 Turbo Encoder 5.0 编码器的问题
hi 各位大神
从该IP的使用手册说明来看应该是支持外部交织器的。但对该 IP仿真
发现交织器加载不进去。具体情况如附件中所示。请大神指点一下。
0 项奖励
2 条回复2
198 次查看
注册日期: ‎08-02-2007
回复: 1 关于 Turbo Encoder 5.0 编码器的问题
Take a look at PG124 November 18, 2015, page 24
Address Generator Options
Address Generator: Set to Internal to use the 3GPP standard for the interleaving function.
To use a different interleaving function, set to External and provide the interleaving
sequence as described in External Address Generator Option.
Address Width: If Address Generator is set to External you can define the length of the
interleaving sequence using this field. See External Address Generator Option for more
information.
0 项奖励
132 次查看
注册日期: ‎10-09-2019
地址长度与待编码的长度一致,我是这么设置的
但是仿真并不正确
0 项奖励
