【Help!】debussy compile vivado ip kernel error Actual for formal wea is not a signal
回复
发帖数: 6
注册日期: ‎12-29-2017
[ 已编辑 ]
--Error:D:\vivado_project\vga_test\vga_test.srcs\sources_1\ip\picture_rom_1bit\sim\picture_rom_1bit.vhd(302):Actual for formal wea is not a signal.
-- Error: D:\vivado_project\vga_test\vga_test.srcs\sources_1\ip\picture_rom_1bit\sim\picture_rom_1bit.vhd(302): Bad actual part of map.
-- Error: D:\vivado_project\vga_test\vga_test.srcs\sources_1\ip\picture_rom_1bit\sim\picture_rom_1bit.vhd(298): Bad port map.
picture_rom_1bit.vhd is the core source file generated by a vivado IP , part of the screenshot below:
what's the mean of the error"Actual for formal wea is not a signal" ?
when calling this rom core,the settings are always enabled, using only three signals,like this:
picture_rom_1bit pic_rom_1b(
       .clka(vga_clk),
       .addra(pic_add),
       .douta(pic_dout_1b)
The source code of "picture_rom_1bit.vhd " is as follows:
-- (c) Copyright 1995-2017 Xilinx, Inc. All rights reserved.
-- This file contains confidential and proprietary information
-- of Xilinx, Inc. and is protected under U.S. and
-- international copyright and other intellectual property
-- laws.
-- DISCLAIMER
-- This disclaimer is not a license and does not grant any
-- rights to the materials distributed herewith. Except as
-- otherwise provided in a valid license issued to you by
-- Xilinx, and to the maximum extent permitted by applicable
-- law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
-- WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
-- AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
-- BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
-- INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
-- (2) Xilinx shall not be liable (whether in contract or tort,
-- including negligence, or under any other theory of
-- liability) for any loss or damage of any kind or nature
-- related to, arising under or in connection with these
-- materials, including for any direct, or any indirect,
-- special, incidental, or consequential loss or damage
-- (including loss of data, profits, goodwill, or any type of
-- loss or damage suffered as a result of any action brought
-- by a third party) even if such damage or loss was
-- reasonably foreseeable or Xilinx had been advised of the
-- possibility of the same.
-- CRITICAL APPLICATIONS
-- Xilinx products are not designed or intended to be fail-
-- safe, or for use in any application requiring fail-safe
-- performance, such as life-support or safety devices or
-- systems, Class III medical devices, nuclear facilities,
-- applications related to the deployment of airbags, or any
-- other applications that could lead to death, personal
-- injury, or severe property or environmental damage
-- (individually and collectively, "Critical
-- Applications"). Customer assumes the sole risk and
-- liability of any use of Xilinx products in Critical
-- Applications, subject only to applicable laws and
-- regulations governing limitations on product liability.
-- THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
-- PART OF THIS FILE AT ALL TIMES.
-- DO NOT MODIFY THIS FILE.
-- IP VLNV: xilinx.com:ip:blk_mem_gen:8.3
-- IP Revision: 1
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
LIBRARY blk_mem_gen_v8_3_1; USE blk_mem_gen_v8_3_1.blk_mem_gen_v8_3_1; ENTITY picture_rom_1bit IS PORT ( clka : IN STD_LOGIC; addra : IN STD_LOGIC_VECTOR(17 DOWNTO 0); douta : OUT STD_LOGIC_VECTOR(0 DOWNTO 0) ); END picture_rom_1bit; ARCHITECTURE picture_rom_1bit_arch OF picture_rom_1bit IS ATTRIBUTE DowngradeIPIdentifiedWarnings : string; ATTRIBUTE DowngradeIPIdentifiedWarnings OF picture_rom_1bit_arch: ARCHITECTURE IS "yes"; COMPONENT blk_mem_gen_v8_3_1 IS GENERIC ( C_FAMILY : STRING; C_XDEVICEFAMILY : STRING; C_ELABORATION_DIR : STRING; C_INTERFACE_TYPE : INTEGER; C_AXI_TYPE : INTEGER; C_AXI_SLAVE_TYPE : INTEGER; C_USE_BRAM_BLOCK : INTEGER; C_ENABLE_32BIT_ADDRESS : INTEGER; C_CTRL_ECC_ALGO : STRING; C_HAS_AXI_ID : INTEGER; C_AXI_ID_WIDTH : INTEGER; C_MEM_TYPE : INTEGER; C_BYTE_SIZE : INTEGER; C_ALGORITHM : INTEGER; C_PRIM_TYPE : INTEGER; C_LOAD_INIT_FILE : INTEGER; C_INIT_FILE_NAME : STRING; C_INIT_FILE : STRING; C_USE_DEFAULT_DATA : INTEGER; C_DEFAULT_DATA : STRING; C_HAS_RSTA : INTEGER; C_RST_PRIORITY_A : STRING; C_RSTRAM_A : INTEGER; C_INITA_VAL : STRING; C_HAS_ENA : INTEGER; C_HAS_REGCEA : INTEGER; C_USE_BYTE_WEA : INTEGER; C_WEA_WIDTH : INTEGER; C_WRITE_MODE_A : STRING; C_WRITE_WIDTH_A : INTEGER; C_READ_WIDTH_A : INTEGER; C_WRITE_DEPTH_A : INTEGER; C_READ_DEPTH_A : INTEGER; C_ADDRA_WIDTH : INTEGER; C_HAS_RSTB : INTEGER; C_RST_PRIORITY_B : STRING; C_RSTRAM_B : INTEGER; C_INITB_VAL : STRING; C_HAS_ENB : INTEGER; C_HAS_REGCEB : INTEGER; C_USE_BYTE_WEB : INTEGER; C_WEB_WIDTH : INTEGER; C_WRITE_MODE_B : STRING; C_WRITE_WIDTH_B : INTEGER; C_READ_WIDTH_B : INTEGER; C_WRITE_DEPTH_B : INTEGER; C_READ_DEPTH_B : INTEGER; C_ADDRB_WIDTH : INTEGER; C_HAS_MEM_OUTPUT_REGS_A : INTEGER; C_HAS_MEM_OUTPUT_REGS_B : INTEGER; C_HAS_MUX_OUTPUT_REGS_A : INTEGER; C_HAS_MUX_OUTPUT_REGS_B : INTEGER; C_MUX_PIPELINE_STAGES : INTEGER; C_HAS_SOFTECC_INPUT_REGS_A : INTEGER; C_HAS_SOFTECC_OUTPUT_REGS_B : INTEGER; C_USE_SOFTECC : INTEGER; C_USE_ECC : INTEGER; C_EN_ECC_PIPE : INTEGER; C_HAS_INJECTERR : INTEGER; C_SIM_COLLISION_CHECK : STRING; C_COMMON_CLK : INTEGER; C_DISABLE_WARN_BHV_COLL : INTEGER; C_EN_SLEEP_PIN : INTEGER; C_USE_URAM : INTEGER; C_EN_RDADDRA_CHG : INTEGER; C_EN_RDADDRB_CHG : INTEGER; C_EN_DEEPSLEEP_PIN : INTEGER; C_EN_SHUTDOWN_PIN : INTEGER; C_EN_SAFETY_CKT : INTEGER; C_DISABLE_WARN_BHV_RANGE : INTEGER; C_COUNT_36K_BRAM : STRING; C_COUNT_18K_BRAM : STRING; C_EST_POWER_SUMMARY : STRING ); PORT ( clka : IN STD_LOGIC; rsta : IN STD_LOGIC; ena : IN STD_LOGIC; regcea : IN STD_LOGIC; wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0); addra : IN STD_LOGIC_VECTOR(17 DOWNTO 0); dina : IN STD_LOGIC_VECTOR(0 DOWNTO 0); douta : OUT STD_LOGIC_VECTOR(0 DOWNTO 0); clkb : IN STD_LOGIC; rstb : IN STD_LOGIC; enb : IN STD_LOGIC; regceb : IN STD_LOGIC; web : IN STD_LOGIC_VECTOR(0 DOWNTO 0); addrb : IN STD_LOGIC_VECTOR(17 DOWNTO 0); dinb : IN STD_LOGIC_VECTOR(0 DOWNTO 0); doutb : OUT STD_LOGIC_VECTOR(0 DOWNTO 0); injectsbiterr : IN STD_LOGIC; injectdbiterr : IN STD_LOGIC; eccpipece : IN STD_LOGIC; sbiterr : OUT STD_LOGIC; dbiterr : OUT STD_LOGIC; rdaddrecc : OUT STD_LOGIC_VECTOR(17 DOWNTO 0); sleep : IN STD_LOGIC; deepsleep : IN STD_LOGIC; shutdown : IN STD_LOGIC; rsta_busy : OUT STD_LOGIC; rstb_busy : OUT STD_LOGIC; s_aclk : IN STD_LOGIC; s_aresetn : IN STD_LOGIC; s_axi_awid : IN STD_LOGIC_VECTOR(3 DOWNTO 0); s_axi_awaddr : IN STD_LOGIC_VECTOR(31 DOWNTO 0); s_axi_awlen : IN STD_LOGIC_VECTOR(7 DOWNTO 0); s_axi_awsize : IN STD_LOGIC_VECTOR(2 DOWNTO 0); s_axi_awburst : IN STD_LOGIC_VECTOR(1 DOWNTO 0); s_axi_awvalid : IN STD_LOGIC; s_axi_awready : OUT STD_LOGIC; s_axi_wdata : IN STD_LOGIC_VECTOR(0 DOWNTO 0); s_axi_wstrb : IN STD_LOGIC_VECTOR(0 DOWNTO 0); s_axi_wlast : IN STD_LOGIC; s_axi_wvalid : IN STD_LOGIC; s_axi_wready : OUT STD_LOGIC; s_axi_bid : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); s_axi_bresp : OUT STD_LOGIC_VECTOR(1 DOWNTO 0); s_axi_bvalid : OUT STD_LOGIC; s_axi_bready : IN STD_LOGIC; s_axi_arid : IN STD_LOGIC_VECTOR(3 DOWNTO 0); s_axi_araddr : IN STD_LOGIC_VECTOR(31 DOWNTO 0); s_axi_arlen : IN STD_LOGIC_VECTOR(7 DOWNTO 0); s_axi_arsize : IN STD_LOGIC_VECTOR(2 DOWNTO 0); s_axi_arburst : IN STD_LOGIC_VECTOR(1 DOWNTO 0); s_axi_arvalid : IN STD_LOGIC; s_axi_arready : OUT STD_LOGIC; s_axi_rid : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); s_axi_rdata : OUT STD_LOGIC_VECTOR(0 DOWNTO 0); s_axi_rresp : OUT STD_LOGIC_VECTOR(1 DOWNTO 0); s_axi_rlast : OUT STD_LOGIC; s_axi_rvalid : OUT STD_LOGIC; s_axi_rready : IN STD_LOGIC; s_axi_injectsbiterr : IN STD_LOGIC; s_axi_injectdbiterr : IN STD_LOGIC; s_axi_sbiterr : OUT STD_LOGIC; s_axi_dbiterr : OUT STD_LOGIC; s_axi_rdaddrecc : OUT STD_LOGIC_VECTOR(17 DOWNTO 0) ); END COMPONENT blk_mem_gen_v8_3_1; ATTRIBUTE X_INTERFACE_INFO : STRING; ATTRIBUTE X_INTERFACE_INFO OF clka: SIGNAL IS "xilinx.com:interface:bram:1.0 BRAM_PORTA CLK"; ATTRIBUTE X_INTERFACE_INFO OF addra: SIGNAL IS "xilinx.com:interface:bram:1.0 BRAM_PORTA ADDR"; ATTRIBUTE X_INTERFACE_INFO OF douta: SIGNAL IS "xilinx.com:interface:bram:1.0 BRAM_PORTA DOUT"; BEGIN U0 : blk_mem_gen_v8_3_1 GENERIC MAP ( C_FAMILY => "artix7", C_XDEVICEFAMILY => "artix7", C_ELABORATION_DIR => "./", C_INTERFACE_TYPE => 0, C_AXI_TYPE => 1, C_AXI_SLAVE_TYPE => 0, C_USE_BRAM_BLOCK => 0, C_ENABLE_32BIT_ADDRESS => 0, C_CTRL_ECC_ALGO => "NONE", C_HAS_AXI_ID => 0, C_AXI_ID_WIDTH => 4, C_MEM_TYPE => 3, C_BYTE_SIZE => 9, C_ALGORITHM => 1, C_PRIM_TYPE => 1, C_LOAD_INIT_FILE => 1, C_INIT_FILE_NAME => "picture_rom_1bit.mif", C_INIT_FILE => "picture_rom_1bit.mem", C_USE_DEFAULT_DATA => 0, C_DEFAULT_DATA => "0", C_HAS_RSTA => 0, C_RST_PRIORITY_A => "CE", C_RSTRAM_A => 0, C_INITA_VAL => "0", C_HAS_ENA => 0, C_HAS_REGCEA => 0, C_USE_BYTE_WEA => 0, C_WEA_WIDTH => 1, C_WRITE_MODE_A => "WRITE_FIRST", C_WRITE_WIDTH_A => 1, C_READ_WIDTH_A => 1, C_WRITE_DEPTH_A => 148480, C_READ_DEPTH_A => 148480, C_ADDRA_WIDTH => 18, C_HAS_RSTB => 0, C_RST_PRIORITY_B => "CE", C_RSTRAM_B => 0, C_INITB_VAL => "0", C_HAS_ENB => 0, C_HAS_REGCEB => 0, C_USE_BYTE_WEB => 0, C_WEB_WIDTH => 1, C_WRITE_MODE_B => "WRITE_FIRST", C_WRITE_WIDTH_B => 1, C_READ_WIDTH_B => 1, C_WRITE_DEPTH_B => 148480, C_READ_DEPTH_B => 148480, C_ADDRB_WIDTH => 18, C_HAS_MEM_OUTPUT_REGS_A => 0, C_HAS_MEM_OUTPUT_REGS_B => 0, C_HAS_MUX_OUTPUT_REGS_A => 0, C_HAS_MUX_OUTPUT_REGS_B => 0, C_MUX_PIPELINE_STAGES => 0, C_HAS_SOFTECC_INPUT_REGS_A => 0, C_HAS_SOFTECC_OUTPUT_REGS_B => 0, C_USE_SOFTECC => 0, C_USE_ECC => 0, C_EN_ECC_PIPE => 0, C_HAS_INJECTERR => 0, C_SIM_COLLISION_CHECK => "ALL", C_COMMON_CLK => 0, C_DISABLE_WARN_BHV_COLL => 0, C_EN_SLEEP_PIN => 0, C_USE_URAM => 0, C_EN_RDADDRA_CHG => 0, C_EN_RDADDRB_CHG => 0, C_EN_DEEPSLEEP_PIN => 0, C_EN_SHUTDOWN_PIN => 0, C_EN_SAFETY_CKT => 0, C_DISABLE_WARN_BHV_RANGE => 0, C_COUNT_36K_BRAM => "5", C_COUNT_18K_BRAM => "0", C_EST_POWER_SUMMARY => "Estimated Power for IP : 2.157347 mW" ) PORT MAP ( clka => clka, rsta => '0', ena => '0', regcea => '0', wea => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), addra => addra, dina => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), douta => douta, clkb => '0', rstb => '0', enb => '0', regceb => '0', web => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), addrb => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 18)), dinb => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), injectsbiterr => '0', injectdbiterr => '0', eccpipece => '0', sleep => '0', deepsleep => '0', shutdown => '0', s_aclk => '0', s_aresetn => '0', s_axi_awid => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 4)), s_axi_awaddr => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 32)), s_axi_awlen => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 8)), s_axi_awsize => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 3)), s_axi_awburst => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 2)), s_axi_awvalid => '0', s_axi_wdata => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), s_axi_wstrb => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 1)), s_axi_wlast => '0', s_axi_wvalid => '0', s_axi_bready => '0', s_axi_arid => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 4)), s_axi_araddr => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 32)), s_axi_arlen => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 8)), s_axi_arsize => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 3)), s_axi_arburst => STD_LOGIC_VECTOR(TO_UNSIGNED(0, 2)), s_axi_arvalid => '0', s_axi_rready => '0', s_axi_injectsbiterr => '0', s_axi_injectdbiterr => '0' ); END picture_rom_1bit_arch;
发帖数: 790
注册日期: ‎06-17-2013
回复: 【求助】debussy编译vivado的ip核报错Actual for formal wea is not a signal
Hi @zhanyue1
This thread is for global and you need to post your thread by English.
If you ask this question, could you post it by Chinese on Chinese forum ?
麻煩你了
发帖数: 6
注册日期: ‎12-29-2017
hi,@watari,thank you very much
Can you tell me how should I do?when I open the Chinese forums:
https://forums.xilinx.com/t5/%E8%B5%9B%E7%81%B5%E6%80%9D%E4%B8%AD%E6%96%87%E7%A4%BE%E5%8C%BA%E8%AE%BA%E5%9D%9B/ct-p/Chinese,
it shows like this:
I post my question by chinese there,I do not know what I did wrong, may I ask how to do it?
