取消
显示结果
搜索替代
您的意思是:
279 次查看
注册日期: ‎04-20-2018
显示屏刷新问题
微信图片_20190425113336.jpg我使用FPGA调显示屏的时候,出现不稳定的黑条?请问这个现象是怎么造成的?
0 项奖励
9 条回复9
258 次查看
注册日期: ‎08-01-2007
回复: 显示屏刷新问题
全是你自己的逻辑? 是什么接口接到显示器? 用到了xilinx的IP?
0 项奖励
250 次查看
注册日期: ‎04-20-2018
回复: 显示屏刷新问题
我是在ADI例程上单独剥离出HDMI显示部分使用的,都是封装好的IP。用SDK调试。
逻辑肯定没问题,因为试其他屏幕是好的,我怀疑是我设置显示的分辨率参数不对,像这样:
static const VideoMode VMODE_1920x1080 = {
.label = "1920x1080@60Hz",
.width = 1920,
.height = 1080,
.hps = 2008,
.hpe = 2052,
.hmax = 2199,
.hpol = 1,
.vps = 1084,
.vpe = 1089,
.vmax = 1124,
.vpol = 1,
.freq = 150 //148.57 is close enough
这个问题我估计是场消隐的参数没给对,您帮我分析一下,我应该怎么修改?
0 项奖励
Scholar watari
240 次查看
注册日期: ‎06-16-2013
回复: 显示屏刷新问题
Hi @geyuer123
Would you make sure video format and setup/hold timing error ?
It seems that there are I mentioned matter.
0 项奖励
218 次查看
注册日期: ‎04-20-2018
回复: 显示屏刷新问题
If the setup/hold time is not satisfied, I should be able to lower the pixel clock frequency to resolve it.However, when I slow down the pixel clock rate, the display won't light up
0 项奖励
Scholar watari
166 次查看
注册日期: ‎06-16-2013
回复: 显示屏刷新问题
Hi @geyuer123
I suggest you to make sure video format. Especially color format.
Would you try it ?
0 项奖励
112 次查看
注册日期: ‎04-20-2018
回复: 显示屏刷新问题
hello,I change the picture  ,ans  the same problem is appeared.Except for the refresh problem on the right, the rest of the image display is normal.
0 项奖励
111 次查看
注册日期: ‎04-20-2018
回复: 显示屏刷新问题
我的屏幕参数见图“屏幕参数”
char label[64]; /* Label describing the resolution */
u32 width; /*Width of the active video frame*/
u32 height; /*Height of the active video frame*/
u32 hps; /*Start time of Horizontal sync pulse, in pixel clocks (active width + H. front porch)*/
u32 hpe; /*End time of Horizontal sync pulse, in pixel clocks (active width + H. front porch + H. sync width)*/
u32 hmax; /*Total number of pixel clocks per line (active width + H. front porch + H. sync width + H. back porch) */
u32 hpol; /*hsync pulse polarity*/
u32 vps; /*Start time of Vertical sync pulse, in lines (active height + V. front porch)*/
u32 vpe; /*End time of Vertical sync pulse, in lines (active height + V. front porch + V. sync width)*/
u32 vmax; /*Total number of lines per frame (active height + V. front porch + V. sync width + V. back porch) */
u32 vpol; /*vsync pulse polarity*/
double freq; /*Pixel Clock frequency*/
程序中设置的参数如下:
static const VideoMode VMODE_CUSTMER_mipi_vertical = {
.label = "720x1280@60Hz",
.width =720,
.height = 1280,
.hps = 736,//736
.hpe = 741,//741
.hmax = 752,//752
.hpol = 0,
.vps = 1296,
.vpe = 1301,
.vmax = 1312,
.vpol = 0,
.freq = 59.2
我是不是参数哪里理解错了?设置错误?
0 项奖励
59 次查看
注册日期: ‎08-01-2007
回复: 显示屏刷新问题
完全不清楚你用的什么设计? 既然你能确保逻辑没有问题, 那硬件呢? 你自己的板卡?
0 项奖励
Scholar watari
34 次查看
注册日期: ‎06-16-2013
回复: 显示屏刷新问题
Hi @geyuer123
Would you make sure video format or color space ? (not video timing)
Best regards
0 项奖励
