取消
显示结果
搜索替代
您的意思是:
152 次查看
注册日期: ‎05-04-2018
关于MPSoC SD卡启动问题
对照UG1209的SD卡启动方式,
1、在Boot Sequence for SD-Boot时,若添加了bit文件,会在加载bit文件时报出
XFSBL_ERROR_BITSTREAM_LOAD_FAIL;
2、若在Boot Sequence for SD-Boot,生成BOOT.bin时不添加bit文件,只添加fsbl.elf、pmu.elf、bl31.elf、u-boot.elf,会在
In Stage 4时卡住,且不提示任何错误信息。
注:以下为pin map(BD的设置中目前只添加了IIC/UART0/SD1),
       和问题1和问题2对应的log信息。
问题2log:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2 Feb 20 2019 - 15:42:49
Reset Mode : System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU3EG
Processor Initialization Done
================= In Stage 2 ============
SD1 Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x3
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x3140
Data word offset: 0x3140
ation Load Address: 0xFFFEA000 .
Execution Address: 0xFFFEA000
Data word offset: 0xE970
Partition Attributes: 0x117
Partition 1 Load Success
======= In Stage 3, Partition No:2 =======
UnEncrypted data Length: 0x4366E
Data word offset: 0x4366E
Total Data word length: 0x4366E
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0x11AB0
Partition Attributes: 0x114
Partition 2 Load Success
All Partitions Loaded
================= In Stage 4 ============
AIB ack status: 0x0
AIB ack status: 0x0
PM Init Success
Protection configuration applied
ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: START.
NOTICE: BL31: v1.4(release):xilinx-v2018.2-dirty
NOTICE: BL31: Built : 15:35:41, Feb 20 2019
NOTICE: BL31: END.
P
问题1log:
Release 2018.2   Feb 19 2019  -  14:21:36
SD1 Boot Mode
SD: rc= 0
Multiboot Reg : 0x0
No of Partitions: 0x5
UnEncrypted data Length: 0x4E86
Data word offset: 0x4E86
Total Data word length: 0x4E86
Destination Load Address: 0xFFDC0000
Execution Address: 0xFFDC9470
Data word offset: 0x6AB0
Partition Attributes: 0x83E
UnEncrypted data Length: 0x339
Data word offset: 0x339
Total Data word length: 0x339
Destination Load Address: 0xFFDD7F80
Execution Address: 0x0
Data word offset: 0xB940
======= In Stage 3, Partition No:3 =======
UnEncrypted data Length: 0x100
Data word offset: 0x100
Total Data word length: 0x100
Destination Load Address: 0xFFDDF6E0
Data word offset: 0xBC80
PMU Firmware 2018.2     Feb 19 2019   14:00:03
PMU_ROM Version: xpbr-v8.1.0-0
DAP_WAKE (MOD-1): Initialized.
LEGACY PWR UP/DN/ISO (MOD-2): Initialized.
Partition 3 Load Success
======= In Stage 3, Partition No:4 =======
UnEncrypted data Length: 0x153E27
Data word offset: 0x153E27
Total Data word length: 0x153E27
Destination Load Address: 0xFFFFFFFF
Data word offset: 0xBD80
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
XPFW: Calling ROM PWRUP Handler..Done
XPFW: Calling ROM Isolation Handler..Done
Non authenticated Bitstream download to start now
DMA transfer done
Partition 4 Load Failed, 0x37
0 项奖励
2 条回复2
137 次查看
注册日期: ‎09-14-2018
回复: 关于MPSoC SD卡启动问题
hi @shiyangcool
1. 可以贴下BIF文件吗?
2. 使用的BSP和硬件是匹配的吗?会不会vivado工程修改了但是BSP没有更新?
供参考~
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
129 次查看
注册日期: ‎05-04-2018
回复: 关于MPSoC SD卡启动问题
以下为bif文件,使用petalinux没起来,现在所有文件都是手动生成。SDK也是从Vivado编译完进行导出的,所以不太可能会是VIVADO更新了没对上。
0 项奖励
