取消
显示结果
搜索替代
您的意思是:
Newbie esc345
814 次查看
注册日期: ‎05-21-2018
MPSOC ZU3EG 系统启动时候卡死
现在遇到这样的问题,同样的代码和逻辑配置文件 在开发板上面一切正常,但是在我们自己的板子上就会出现kernel 启动卡死不知道是什么问题,log如下:
Xilinx Zynq MP First Stage Boot Loader
Release 2017.2 Mar 4 2019 - 16:55:13
NOTICE: ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmwa re
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.3(release):
NOTICE: BL31: Built : 15:37:56, Mar 9 2018
PMUFW: v0.3
U-Boot 2017.01 (Mar 04 2019 - 17:29:39 +0800) Xilinx ZynqMP ZCU102 revB
I2C: Error, wrong i2c adapter 0 max 0 possible
ready
DRAM: 2 GiB
EL Level: EL2
Chip ID: xczu3eg
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Net: ZYNQ GEM: ff0e0000, phyaddr 9, interface rgmii-id
Warning: ethernet@ff0e0000 (eth0) using random MAC address - fe:7b:c4:ce:6b:de
eth0: ethernet@ff0e0000
device 0 offset 0x850000, size 0x80000
SF: 524288 bytes @ 0x850000 Read: OK
device 0 offset 0x900000, size 0xf00000
SF: 15728640 bytes @ 0x900000 Read: OK
## Flattened Device Tree blob at 04000000
Booting using the fdt blob at 0x4000000
Loading Device Tree to 000000000fff5000, end 000000000ffff1bc ... OK
Starting kernel ...
[ 0.000000] test cp3
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.0 (rocket@ubuntu) (gcc version 6.2.1 20161114 (Linaro GCC Snapshot 6.2-2016.11) ) #213 SMP Thu Feb 28 16:56:21 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 128 MiB at 0x0000000068000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc067f78000 s47384 r8192 d30440 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
请问下大概会是什么问题导致?DDR 测试正常
0 项奖励
6 条回复6
763 次查看
注册日期: ‎09-14-2018
回复: MPSOC ZU3EG 系统启动时候卡死
@esc345
不是很好判断。和开发板硬件有哪些区别吗,用的同一个镜像?
0 项奖励
Newbie esc345
759 次查看
注册日期: ‎05-21-2018
只是外设有一些区别,用的是同一个套 kernel
0 项奖励
748 次查看
注册日期: ‎09-14-2018
@esc345
意思是直接拿开发板的镜像在自己板子上运行的吗?如果外设有区别,镜像基本不能在别的板子上正常运行
0 项奖励
Newbie esc345
745 次查看
注册日期: ‎05-21-2018
是我描述的不是很清楚,现在的情况是这样的:
1.kernel是用2017.2的源码编译的,在开发板上面跑一点问题没有
2.现在用同样的kernel源码,但是使用针对我们板子生成的fsbl跑是目前帖子上的这个情况
3.还是使用同样的kernel源码,在我们之前一批做的板子上面跑也是没问题
4.DRAM测试过没有问题
5.如果是外设不一样导致的卡死也不应该死在这里,parse_early_param都没有跑到
0 项奖励
733 次查看
注册日期: ‎08-26-2010
Hi @esc345,
看到一个I2C的error:
之前注意到在2017.2上出现过类似的问题,建议用2017.3或者更新的能否解决这个问题?
Simon
0 项奖励
Observer jack.lv
506 次查看
注册日期: ‎09-11-2018
我碰到过类似卡死的问题,最后发现是由于uart口multidriver导致的
0 项奖励
