04-26-2019 10:10 AM - 编辑日期 04-26-2019 10:26 AM
大家好,我在用petalinux2018.2做sd卡启动程序的时候,发现出现如下问题:
环境:petalinux2018.2 vivado2018.2 zu3
U-Boot 2018.01 (Apr 25 2019 - 01:05:10 +0800) Xilinx ZynqMP ZCU102 rev1.0 I2C: ready DRAM: 2 GiB EL Level: EL2 Chip ID: zu3eg MMC: sdhci@ff170000: 0 sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms. sdhci_send_command: MMC: 0 busy timeout. sdhci_send_command: MMC: 0 busy timeout. mmc_init: -70, time 7439 ** Bad device mmc 0 ** Using default environment In: serial@ff010000 Out: serial@ff010000 Err: serial@ff010000 Model: ZynqMP template Board: Xilinx ZynqMP Bootmode: SD_MODE1 Net: ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id eth0: ethernet@ff0e0000 ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT ! Hit any key to stop autoboot: 0 sdhci_set_clock: Timeout to wait cmd & data inhibit sdhci_set_clock: Timeout to wait cmd & data inhibit sdhci_send_command: MMC: 0 busy timeout. mmc_init: -70, time 3254 ** Bad device mmc 0 ** sdhci_set_clock: Timeout to wait cmd & data inhibit sdhci_set_clock: Timeout to wait cmd & data inhibit sdhci_send_command: MMC: 0 busy timeout. mmc_init: -70, time 3254 ZynqMP>
之前在使用没有问题,sd卡能够启动,并且进入rootfs。最新做的程序(boot.bin image.ub)出现上述问题,但更换为之前的boot.bin image.ub 就可以正常启动。
修改时间 04-26-2019 11:16 AM
你前面的boot.bin和image.ub也是petalinux 2018.2生成的么?基于同一个hdf文件?你最好先做一下交叉实验,判断一下是fsbl初始化sd controller有问题还是u-boot有问题。比如在sdk里面生成xilffs library example的application,然后和fsbl生成boot.bin就可以在standalone环境下测试sd,这个测试会format sd卡然后在sd卡里创建一个文件,所以请保存好sd卡里原有的文件。
下面这个article是MPSoC器件的SD checklist,看一下吧。
