取消
显示结果
搜索替代
您的意思是:
Observer mxc528169645
299 次查看
注册日期: ‎06-19-2018
ZYNQ7000系列 所能挂载的SD卡容量问题
百度很多人说ZYNQ 7000使用的是SD2.0规范,所以只能最大支持到32GB。
查看文档ug585-ZYNQ-7000-TRM中有一段说明:
The SD/SDIO controller is compatible with the standard SD Host Controller Specification Version 2.0 Part A2 with SDMA (single operation DMA), ADMA1 (4 KB boundary limited DMA), and ADMA2(ADMA2 allows data of any location and any size to be transferred in a 32-bit system memory -scatter-gather DMA) support. The core also supports up to seven functions in SD1, SD4, but does not support SPI mode. The Zynq-7000 AP SoC is expected to work with eMMC devices because the protocol is the same as SD, but this has not been extensively verified. Users must be careful to meet all timing requirements as they might or might not comply with eMMC. It does support SD high-speed (SDHS) and SD High Capacity (SDHC) card standards. The user should be familiar with the SD2.0/SDIO 2.0 specifications.
确实说明了是SD2.0规范。
那么是否最大SD容量为32GB?
我手上有一块XC7Z035FFG676-2的芯片的开发板,是否SD卡最大容量也为32GB呢?
请大神指点
0 项奖励
1 条回复1
271 次查看
注册日期: ‎05-23-2018
回复: ZYNQ7000系列 所能挂载的SD卡容量问题
Hi, @mxc528169645
可以参考一下这个AR: https://www.xilinx.com/support/answers/50991.html
SD卡的容量可以大于32GB。
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
