取消
显示结果
搜索替代
您的意思是:
1,613 次查看
注册日期: ‎06-07-2018
xilinx sdk(2017.4版)编译NE10 报错 不知怎么解决?
转到解答
Description Resource Path Location Type
inlining failed in call to always_inline 'vadd_f32': target specific option mismatch test line 532, external location: e:\xilinx\sdk\2017.4\gnu\aarch32\nt\gcc-arm-none-eabi\lib\gcc\arm-none-eabi\6.2.1\include\arm_neon.h C/C++ Problem
0 项奖励
1 个已接受解答
已接受的解答
1,606 次查看
注册日期: ‎05-23-2018
回复: xilinx sdk(2017.4版)编译NE10 报错 不知怎么解决?
转到解答
Hi, @liuxiaowa271739
报错信息中提示的错误处代码是什么样的?有关于neon的编译选项是怎么设置的?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
在原帖中查看解决方案
0 项奖励
11 条回复11
1,607 次查看
注册日期: ‎05-23-2018
转到解答
在原帖中查看解决方案
0 项奖励
1,592 次查看
注册日期: ‎06-07-2018
转到解答
你好!用的sdk 自带的LWIP echo server 裸机 例子,编译选项 -mvectorize-with-neon-quad -mcpu=cortex-a9 -ftree-vectorize -mfpu=neon -mfpu=vfpv3 -mfloat-abi=hard -nostartfiles -Wall -Wextra
报错处代码:
ne10_result_t ne10_addc_float_neon (ne10_float32_t * dst, ne10_float32_t * src, const ne10_float32_t cst, ne10_uint32_t count)
NE10_DstSrcCst_DO_COUNT_TIMES_FLOAT_NEON
n_dst = vaddq_f32 (n_src, n_cst);
n_rest = vadd_f32 (n_rest, n_rest_cst);
下面是报错信息:
e:\xilinx\sdk\2017.4\gnu\aarch32\nt\gcc-arm-none-eabi\lib\gcc\arm-none-eabi\6.2.1\include\arm_neon.h:9530:1: error: inlining failed in call to always_inline 'vst1q_f32': target specific option mismatch
vst1q_f32 (float32_t * __a, float32x4_t __b)
In file included from E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/macros.h:32:0,
from ../NE10/modules/math/NE10_addc.neon.c:36:
E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/factor.h:123:6: note: called from here
vst1q_f32 ( (float32_t*)dst , n_dst ); /* store the results back */ \
E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/factor.h:145:6: note: in definition of macro 'NE10_DstSrcCst_OPERATION_FLOAT_NEON'
loopCode1; \
E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/macros.h:48:9: note: in expansion of macro 'NE10_DstSrcCst_MAINLOOP_FLOAT_NEON'
NE10_DstSrcCst_MAINLOOP_FLOAT_NEON(loopCode1); , \
../NE10/modules/math/NE10_addc.neon.c:41:5: note: in expansion of macro 'NE10_DstSrcCst_DO_COUNT_TIMES_FLOAT_NEON'
标记 (1)
0 项奖励
1,576 次查看
注册日期: ‎06-07-2018
转到解答
报错处代码:
下面是报错信息:hg.jpgerrors
loopCode1; \
0 项奖励
1,542 次查看
注册日期: ‎05-23-2018
转到解答
从报错信息看来是数据类型不匹配导致的,你的vst1q_f32 ( (float32_t*)dst , n_dst ); 中的n_dst是怎么定义的?
0 项奖励
1,519 次查看
注册日期: ‎06-07-2018
转到解答
这是SDK自带的库文件截图,里面定义了,如下:
0 项奖励
1,494 次查看
注册日期: ‎05-23-2018
转到解答
我指的是E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/factor.h中的第123行处代码vst1q_f32 ( (float32_t*)dst , n_dst );。报错信息显示该处函数的实参类型与库文件中的不匹配。你的相关代码是什么样的?另外,E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/factor.h:145:6处的宏定义也有报错,可以把这些代码贴出来吗?
0 项奖励
1,459 次查看
注册日期: ‎06-07-2018
转到解答
这个是NE10的库文件  见附件   E:\lwh\Axi_Hp\project_1817channel_radio.sdk\test\NE10\common/factor.h  erA.jpg
0 项奖励
1,451 次查看
注册日期: ‎05-23-2018
转到解答
感觉是宏定义在调用的过程的顺序上存在问题,方便把所有代码打包发送上来吗?另外,您也可以自己检查一下代码,保证NE10_DstSrcCst_MAINLOOP_FLOAT_NEON这个宏在被调用时,n_dst已经被定义为float32*4_t的类型。
1,390 次查看
注册日期: ‎06-07-2018
转到解答
0 项奖励
1,294 次查看
注册日期: ‎06-07-2018
转到解答
0 项奖励
Newbie qianxun
654 次查看
注册日期: ‎05-13-2019
转到解答
你好,请问你问题解决了吗?能分享一下怎么用SDK编译NE10吗?万分感谢。。。
0 项奖励
