取消
显示结果
搜索替代
您的意思是:
Observer yehaiyang
719 次查看
注册日期: ‎09-29-2018
zynq amp模式下cpu1无法使用xadc进行外部采样
转到解答
硬件平台:zynq-7020
vivado版本:2017.04
AMP模式:参考1078,cpu0跑linux系统,cpu1跑裸机程序;
1.工程配置:需要对外部模拟信号进行采样,没有使用专用的ADC差分引脚,而是使用 fpga中的XADC IP核,然后使用EMIO定义的VP、VN引脚,如下:
2.通过petalinux软件生成对应的烧写文件,其中设备树dts中配置如下:
/*ps侧的设备节点*/
amba {
u-boot,dm-pre-reloc;
compatible = "simple-bus";
#address-cells = <0x1>;
#size-cells = <0x1>;
interrupt-parent = <0x4>;
ranges;
    adc@f8007100 {
          compatible = "xlnx,zynq-xadc-1.00.a";
         reg = <0xf8007100 0x20>;
        interrupts = <0x0 0x7 0x4>;
       clocks = <0x1 0xc>;
/*其他设备节点*、
/*pl侧的设备节点*/
amba_pl {
ranges;
xadc_wiz@43c10000 {
clock-names = "ref_clk";
clocks = <0x1 0x0>;
compatible = "xlnx,axi-xadc-1.00.a";
reg = <0x43c10000 0x10000>;
xlnx,alarm-limit-r0 = <0xb5ed>;
xlnx,alarm-limit-r1 = <0x57e4>;
xlnx,alarm-limit-r10 = <0x5555>;
xlnx,alarm-limit-r11 = <0x5111>;
xlnx,alarm-limit-r12 = <0x9999>;
xlnx,alarm-limit-r13 = <0x91eb>;
xlnx,alarm-limit-r14 = <0x6aaa>;
xlnx,alarm-limit-r15 = <0x6666>;
xlnx,alarm-limit-r2 = <0xa147>;
xlnx,alarm-limit-r3 = <0xca33>;
xlnx,alarm-limit-r4 = <0xa93a>;
xlnx,alarm-limit-r5 = <0x52c6>;
xlnx,alarm-limit-r6 = <0x9555>;
xlnx,alarm-limit-r7 = <0xae4e>;
xlnx,alarm-limit-r8 = <0x5999>;
xlnx,alarm-limit-r9 = <0x5111>;
xlnx,configuration-r0 = <0x2003>;
xlnx,configuration-r1 = <0x31a0>;
xlnx,configuration-r2 = <0x400>;
xlnx,dclk-frequency = <0x64>;
xlnx,external-mux = "none";
xlnx,external-mux-channel = "VP_VN";
xlnx,external-muxaddr-enable = <0x0>;
xlnx,fifo-depth = <0x7>;
xlnx,has-axi = <0x1>;
xlnx,has-axi4stream = <0x0>;
xlnx,has-busy = <0x1>;
xlnx,has-channel = <0x1>;
xlnx,has-convst = <0x0>;
xlnx,has-convstclk = <0x0>;
xlnx,has-dclk = <0x1>;
xlnx,has-drp = <0x0>;
xlnx,has-eoc = <0x1>;
xlnx,has-eos = <0x1>;
xlnx,has-external-mux = <0x0>;
xlnx,has-jtagbusy = <0x0>;
xlnx,has-jtaglocked = <0x0>;
xlnx,has-jtagmodified = <0x0>;
xlnx,has-ot-alarm = <0x1>;
xlnx,has-reset = <0x0>;
xlnx,has-temp-bus = <0x0>;
xlnx,has-user-temp-alarm = <0x1>;
xlnx,has-vbram-alarm = <0x0>;
xlnx,has-vccaux-alarm = <0x1>;
xlnx,has-vccddro-alarm = <0x1>;
xlnx,has-vccint-alarm = <0x1>;
xlnx,has-vccpaux-alarm = <0x1>;
xlnx,has-vccpint-alarm = <0x1>;
xlnx,has-vn = <0x1>;
xlnx,has-vp = <0x1>;
xlnx,include-intr = <0x1>;
xlnx,sampling-rate = "961538.4615384615";
xlnx,sequence-r0 = <0x100>;
xlnx,sequence-r1 = <0x0>;
xlnx,sequence-r2 = <0x0>;
xlnx,sequence-r3 = <0x0>;
xlnx,sequence-r4 = <0x0>;
xlnx,sequence-r5 = <0x0>;
xlnx,sequence-r6 = <0x0>;
xlnx,sequence-r7 = <0x0>;
xlnx,sim-file-name = "design";
xlnx,sim-file-rel-path = "./";
xlnx,sim-file-sel = "Default";
xlnx,vaux0 = <0x0>;
xlnx,vaux1 = <0x0>;
xlnx,vaux10 = <0x0>;
xlnx,vaux11 = <0x0>;
xlnx,vaux12 = <0x0>;
xlnx,vaux13 = <0x0>;
xlnx,vaux14 = <0x0>;
xlnx,vaux15 = <0x0>;
xlnx,vaux2 = <0x0>;
xlnx,vaux3 = <0x0>;
xlnx,vaux4 = <0x0>;
xlnx,vaux5 = <0x0>;
xlnx,vaux6 = <0x0>;
xlnx,vaux7 = <0x0>;
xlnx,vaux8 = <0x0>;
xlnx,vaux9 = <0x0>;
3.个人测试:
参考官方的一些回复,当使用AMP模式,cpu1需要使用ps侧的外设时,需要准守一下原则:
第一:bootargs中需要包含 clk_ignore_unused 参数
第二:当设备只给cpu1使用时,需要在设备树dts中将对应的设备节点删除或是注释掉,避免cpu0的linux系统对其占用;
进行如下测试:
cpu1的裸机程序中有对xadc的初始化和使用
(1)当使用sdk进行在线调试时,xadc完成初始化并能对外部模拟信号采样处理,验证硬件电路与fpga.bit配置文件无误;
以下进行双核运行,cpu0的linux启动后,在启动cpu1的裸机程序
(2)dts中保留上述的adc@f8007100和xadc_wiz@43c10000节点,生成dtb并完成烧写启动,结果:
           cpu1中的xadc能完成初始化,但是采集的外部模拟信号一直是空值;
(3)dts中注释上述的adc@f8007100,保留xadc_wiz@43c10000节点,生成dtb并完成烧写启动,结果:
           cpu1程序卡在xadc的初始化过程中,具体函数是:XAdcPs_SelfTest(),即xadc自检
请问:这种情况有仁兄遇到过吗?
1 个已接受解答
已接受的解答
671 次查看
注册日期: ‎05-11-2010
回复: zynq amp模式下cpu1无法使用xadc进行外部采样
转到解答
如果cpu1 standalone application可以正常使用XADC,我认为你可以在cpu0 linux device tree里去掉xadc所有node。另外,你需要按照AMP的要求设计系统,比如,cpu0和cpu1使用的DDR范围要分开,cpu1 application要增加duse_amp flag,cpu1 application里要把可访问DDR范围设为Lv2 uncacheable, cpu1 application的中断要设置目标cpu为cpu1.
在原帖中查看解决方案
3 条回复3
672 次查看
注册日期: ‎05-11-2010
转到解答
在原帖中查看解决方案
Observer yehaiyang
645 次查看
注册日期: ‎09-29-2018
转到解答
0 项奖励
Visitor markyang70
484 次查看
注册日期: ‎06-15-2018
转到解答
Hi yzhang
   您好,關於"cpu1 application的中断要设置目标cpu为cpu1." 這段話,
   要在哪裡設置,是否有詳細的說明,謝謝。
0 项奖励
