取消
显示结果
搜索替代
您的意思是:
1,547 次查看
注册日期: ‎05-24-2018
用OpenAMP实现多处理器不同功能
转到解答
在ZU+上,如何利用OpenAMP使四核A53分开运行,并使R5运行RTOS?
0 项奖励
1 个已接受解答
已接受的解答
1,546 次查看
注册日期: ‎05-24-2018
回复: 用OpenAMP实现多处理器不同功能
转到解答
感谢jovitac,问题已解决。
UG1186中的"ZynqMP> bootm $netstart - $netstart 0x14000000"出错,实际应为
ZynqMP> bootm $netstart $netstart 0x14000000
在原帖中查看解决方案
0 项奖励
3 条回复3
1,504 次查看
注册日期: ‎02-16-2012
转到解答
运行Linux,Linux会自动把各个进程分配到不同的a53。对于R5,请看OpenAMP的文档。看了文档,还有具体问题吗?
0 项奖励
1,474 次查看
注册日期: ‎05-24-2018
转到解答
我按照UG1186中“Petalinux Images Quick Try”的步骤,用petalinux从xilinx-zcu102-v2017.3-final.bsp中创建工程,将BOOT.BIN image.ub openamp.dtb三个文件放入SD卡,u-boot启动ZU+的板子。
执行ZynqMP> mmcinfo && fatload mmc 0 ${netstart} ${kernel_img} && fatload mmc 0 0x14000000 openamp.dtb
执行ZynqMP> bootm $netstart - $netstart 0x14000000
出现
[    4.940253] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[    4.947672] Please append a correct "root=" boot option; here are the available partitions:
[    4.955997] 0100           65536 ram0
[    4.955999]  (driver?)
[    4.962065] 0101           65536 ram1
[    4.962066]  (driver?)
[    4.968137] 0102           65536 ram2
[    4.968139]  (driver?)
[    4.974217] 0103           65536 ram3
[    4.974219]  (driver?)
[    4.980294] 0104           65536 ram4
[    4.980295]  (driver?)
[    4.986371] 0105           65536 ram5
[    4.986372]  (driver?)
[    4.992447] 0106           65536 ram6
[    4.992448]  (driver?)
[    4.998524] 0107           65536 ram7
[    4.998525]  (driver?)
[    5.004600] 0108           65536 ram8
[    5.004602]  (driver?)
[    5.010673] 0109           65536 ram9
[    5.010675]  (driver?)
[    5.016754] 010a           65536 ram10
[    5.016756]  (driver?)
[    5.022913] 010b           65536 ram11
[    5.022915]  (driver?)
[    5.029081] 010c           65536 ram12
[    5.029082]  (driver?)
[    5.035240] 010d           65536 ram13
[    5.035242]  (driver?)
[    5.041407] 010e           65536 ram14
[    5.041409]  (driver?)
[    5.047567] 010f           65536 ram15
[    5.047568]  (driver?)
[    5.053738] 1f00           30720 mtdblock0
[    5.053740]  (driver?)
[    5.060241] 1f01             256 mtdblock1
[    5.060243]  (driver?)
[    5.066752] 1f02           36864 mtdblock2
[    5.066754]  (driver?)
[    5.073266] 1f03           63232 mtdblock3
[    5.073268]  (driver?)
[    5.079773] b300        15558144 mmcblk0
[    5.079775]  driver: mmcblk
[    5.086548]   b301          512000 mmcblk0p1 91141cd5-01
[    5.086550]
[    5.093319]   b302        15045120 mmcblk0p2 91141cd5-02
[    5.093320]
[    5.100086] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    5.108337] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.2 #1
[    5.115539] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    5.120485] Call trace:
[    5.122923] [<ffffff8008088c58>] dump_backtrace+0x0/0x368
[    5.128301] [<ffffff8008088fd4>] show_stack+0x14/0x20
[    5.133336] [<ffffff8008a13b78>] dump_stack+0x9c/0xbc
[    5.138371] [<ffffff800809bdc0>] panic+0x11c/0x274
[    5.143146] [<ffffff8008d61124>] mount_block_root+0x1a8/0x27c
[    5.148874] [<ffffff8008d61430>] mount_root+0x11c/0x134
[    5.154082] [<ffffff8008d615b4>] prepare_namespace+0x16c/0x1b4
[    5.159899] [<ffffff8008d60d44>] kernel_init_freeable+0x1b8/0x1d8
[    5.165976] [<ffffff8008a25ee0>] kernel_init+0x10/0x100
[    5.171183] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    5.176478] SMP: stopping secondary CPUs
[    5.180384] Kernel Offset: disabled
[    5.183855] CPU features: 0x002004
[    5.187240] Memory Limit: none
[    5.190282] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
0 项奖励
1,547 次查看
注册日期: ‎05-24-2018
转到解答
感谢jovitac,问题已解决。
在原帖中查看解决方案
0 项奖励
