取消
显示结果
搜索替代
您的意思是:
Visitor yaoyh008
799 次查看
注册日期: ‎05-29-2018
PS如何在linux下访问PL的寄存器
我使用的芯片是Zynq UltraScale+ MPSOC EG,我们有一些外设是连接到PL侧的,因此PL内部有一些控制和状态寄存器需要PS侧访问,我们的开发环境是Vivado+petalinux,请问如何在linux下访问FPGA内部我们定义的寄存器?
我们看到UG1085的System address章节有关于system address map的描述,PL是否就是其中的某一段物理地址?
访问FPGA就通过把物理地址映射为虚拟地址就可以了吗?不知道我理解的对不对。
0 项奖励
4 条回复4
Visitor von_fgb
787 次查看
注册日期: ‎06-30-2018
回复: PS如何在linux下访问PL的寄存器
路过
0 项奖励
Newbie clarkzhu
772 次查看
注册日期: ‎03-20-2018
你需要封装你那个ip 挂接到axi总线上,之后就可以用block design 来添加你这个ip了。
0 项奖励
655 次查看
注册日期: ‎05-23-2018
Hi, @yaoyh008
在standalone下,PS对PL寄存器的访问是通过对其物理地址的访问实现的;在linux中,driver将物理地址映射为虚拟地址,通过虚拟地址实现对寄存器的访问。
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
594 次查看
注册日期: ‎11-10-2015
devmem2了解一下,源码随便一搜便有。
这里贴出来,方便你使用。
 * devmem2.c: Simple program to read/write from/to any location in memory.
 *  Copyright (C) 2000, Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl)
 * This software has been developed for the LART computing board
 * (http://www.lart.tudelft.nl/). The development has been sponsored by
 * the Mobile MultiMedia Communications (http://www.mmc.tudelft.nl/)
 * and Ubiquitous Communications (http://www.ubicom.tudelft.nl/)
 * projects.
 * The author can be reached at:
 *  Jan-Derk Bakker
 *  Information and Communication Theory Group
 *  Faculty of Information Technology and Systems
 *  Delft University of Technology
 *  P.O. Box 5031
 *  2600 GA Delft
 *  The Netherlands
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <signal.h>
#include <fcntl.h>
#include <ctype.h>
#include <termios.h>
#include <sys/types.h>
#include <sys/mman.h>
#define FATAL do { fprintf(stderr, "Error at line %d, file %s (%d) [%s]\n", \
  __LINE__, __FILE__, errno, strerror(errno)); exit(1); } while(0)
#define MAP_SIZE 4096UL
#define MAP_MASK (MAP_SIZE - 1)
int main(int argc, char **argv) {
    int fd;
    void *map_base, *virt_addr;
	unsigned long read_result, writeval;
	off_t target;
	int access_type = 'w';
	if(argc < 2) {
		fprintf(stderr, "\nUsage:\t%s { address } [ type [ data ] ]\n"
			"\taddress : memory address to act upon\n"
			"\ttype    : access operation type : [b]yte, [h]alfword, [w]ord\n"
			"\tdata    : data to be written\n\n",
			argv[0]);
		exit(1);
	target = strtoul(argv[1], 0, 0);
	if(argc > 2)
		access_type = tolower(argv[2][0]);
    if((fd = open("/dev/mem", O_RDWR | O_SYNC)) == -1) FATAL;
    printf("/dev/mem opened.\n");
    fflush(stdout);
    /* Map one page */
    map_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, target & ~MAP_MASK);
    if(map_base == (void *) -1) FATAL;
    printf("Memory mapped at address %p.\n", map_base);
    fflush(stdout);
    virt_addr = map_base + (target & MAP_MASK);
    switch(access_type) {
		case 'b':
			read_result = *((unsigned char *) virt_addr);
			break;
		case 'h':
			read_result = *((unsigned short *) virt_addr);
			break;
		case 'w':
			read_result = *((unsigned long *) virt_addr);
			break;
		default:
			fprintf(stderr, "Illegal data type '%c'.\n", access_type);
			exit(2);
    printf("Value at address 0x%X (%p): 0x%X\n", target, virt_addr, read_result);
    fflush(stdout);
	if(argc > 3) {
		writeval = strtoul(argv[3], 0, 0);
			case 'b':
				*((unsigned char *) virt_addr) = writeval;
				break;
			case 'h':
				*((unsigned short *) virt_addr) = writeval;
				break;
			case 'w':
				*((unsigned long *) virt_addr) = writeval;
				break;
		printf("Written 0x%X; readback 0x%X\n", writeval, read_result);
		fflush(stdout);
	if(munmap(map_base, MAP_SIZE) == -1) FATAL;
    close(fd);
    return 0;
使用:
   devmem2 { address } [ type [ data ] ]
    address : 物理地址
    如果是要修改该地址的数据,需要填入下面的参数;如果只是读取,省略即可
    type :要访问的数据类型 : [b]yte, [h]alfword, [w]ord
    data :想要写入的数据
 BestRegards,
 HSQ
