取消
显示结果
搜索替代
您的意思是:
Visitor y493408296
227 次查看
注册日期: ‎11-23-2018
SDSoC application project building failed based on the official platform
I use the SDX 2018.2 to run a application example based on the officail zcu102 platform.It is always failing to build the project.It says that:
I/O error : Bad file descriptor
I/O error : flush error
ERROR: [SdsCompiler 83-5106] Platform specified as zcu106 but the hw platform XML file was not found - is the platform name correct and is the path to the platform correct (if required)?
ERROR: [SdsCompiler 83-5004] Build failed
I went to the dict and find the .dsa and .spfm files in the correspnding dict and try to change the tool chain but it has no effect.So I am here for help.Thanks for looking this
0 项奖励
2 条回复2
180 次查看
注册日期: ‎05-27-2018
回复: SDSoC application project building failed based on the official platform
Hi @y493408296,
     报错信息显示的你使用的平台是ZCU0106,确认一下你的platform选择有没有错误。
     另,参考一下这个链接, 检查一下你的 SDx Project Settings
谢谢,
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
Visitor y493408296
144 次查看
注册日期: ‎11-23-2018
您好:
      我尝试在win10下安装这个软件怎么都是无法编译,没法使用自带的platform,提示IO flush error,无法找到xml文件。但是我在ubuntu18.04环境下安装后,并没有出现这个问题,我尝试修改win10下环境变量的设置,但依然没用,请问win10 的问题是什么导致的。
0 项奖励
