取消
显示结果
搜索替代
您的意思是:
Visitor nick_ctrl
307 次查看
注册日期: ‎09-12-2018
XSCT下PMU状态
根据官方wiki :https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841724/PMU+Firmware#PMUFirmware-DebuggingPMUFWusingSDK
芯片启动成功connect后查看状态应该是如下的:
而我自己生成的PMU,在XSCT下查看状态的时候如下:
PMU下无显示,也无法对其进行操作,而且将生成的pmufw.elf加入BOOT.bin 中,上电启动打印信息里也没有PMU的相关信息,且uboot启动不成功,如下:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2 Feb 20 2019 - 15:42:49
Reset Mode : System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU3EG
Processor Initialization Done
================= In Stage 2 ============
SD1 Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x3
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x3140
Data word offset: 0x3140
ation Load Address: 0xFFFEA000 .
Execution Address: 0xFFFEA000
Data word offset: 0xE970
Partition Attributes: 0x117
Partition 1 Load Success
======= In Stage 3, Partition No:2 =======
UnEncrypted data Length: 0x4366E
Data word offset: 0x4366E
Total Data word length: 0x4366E
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0x11AB0
Partition Attributes: 0x114
Partition 2 Load Success
All Partitions Loaded
================= In Stage 4 ============
AIB ack status: 0x0
AIB ack status: 0x0
PM Init Success
Protection configuration applied
ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.4(release):xilinx-v2018.2-dirty
NOTICE: BL31: Built : 15:35:41, Feb 20 2019
P
最后那个 “P” 也是打印出来的,请帮忙看看这是为何?
0 项奖励
3 条回复3
288 次查看
注册日期: ‎05-23-2018
回复: XSCT下PMU状态
Hi, @nick_ctrl
PMU是如何生成的?用的工具版本是什么?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
Visitor nick_ctrl
284 次查看
注册日期: ‎09-12-2018
回复: XSCT下PMU状态
Hi @weiyil
工具版本为2018.2,PMU就是在 sdk 里面生成的,File->new->application project->pmu
fsbl.bif文件如下:
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
[fsbl_config]a53_x64
[bootloader]D:\xilinx_vivado_workspace\ZU3\project_1\project_1.sdk\FSBL\Debug\FSBL.elf
[pmufw_image]D:\xilinx_vivado_workspace\ZU3\project_1\project_1.sdk\pmufw\Debug\pmufw.elf
[destination_cpu = a53-0, exception_level = el-3, trustzone]C:\Users\Nick\Desktop\zu3\bl31.elf
[destination_cpu = a53-0, exception_level = el-2]C:\Users\Nick\Desktop\zu3\u-boot.elf
0 项奖励
252 次查看
注册日期: ‎05-23-2018
回复: XSCT下PMU状态
Hi, @nick_ctrl
可以参考一下这个链接。
https://forums.xilinx.com/t5/Embedded-Boot-and-Configuration/ZynqU-Boot-from-QSPI-hangs-after-FSBL-and-PMU-messages-XCU19EG/td-p/874382
0 项奖励
