取消
显示结果
搜索替代
您的意思是:
Visitor waming@zhen
314 次查看
注册日期: ‎11-27-2018
ZynqMP Linux Master running on APU with RPMsg in userspace and 2 RPU slaves
    我在按照UG1186 和  wiki-OpenAMP+2018.2 所描述的步骤来实现:ZynqMP Linux Master running on APU with RPMsg in userspace and 2 RPU slaves 时遇到了一个问题。
    我使用的工具及版本如下:
    petalinux: 2018.2
    xsdk: 2018.2
    硬件平台:ZCU102.revirsion1.0
    我需要实现的应用场景如下:
    Master: APU 运行 Linux 系统,有两个应用程序 linux-testapp-to-r5-0 和 linux-testapp-to-r5-1,这两个应用程序都是echo_test程序;
    Slaver: RPU_0 运行 freeRTOS 系统,有一个echo_test应用程序,名称为 freeRTOS_echo_test_r5_0;
    Slaver: PRU_1 运行 freeRTOS 系统,有一个echo_test应用程序,名称为 freeRTOS_echo_test_r5_1
    以下是我按照 UG1186 和 Wiki 的描述对相关文档做的修改:
    1. 在[system-user.dtsi] 添加以下内容:
    reserved-memory {
        #address-cells = <2>;
        #size-cells = <2>;
        ranges;
        /* Reserved memory for both firmware and shared memory */
        rproc_0_reserved: rproc@3ed000000 {
            no-map;
            reg = <0x0 0x3ed00000 0x0 0x8000000>;
    amba {
        vring: vring@0 {
            compatible = "vring_uio";
            reg = <0x0 0x3ed40000 0x0 0x40000>;
        shm0: shm@0 {
            compatible = "shm_uio";
            reg = <0x0 0x3ed80000 0x0 0x80000>;
        vring1: vring@1 {
            reg = <0x0 0x3ef00000 0x0 0x40000>;
        shm1: shm@1 {
            reg = <0x0 0x3ef40000 0x0 0x80000>;
        ipi0: ipi@0 {
            compatible = "ipi_uio";
            reg = <0x0 0xff340000 0x0 0x1000>;
            interrupt-parent = <&&gic>;
            interrupts = <0 29 4>;
注意:interrupt-parent = <&&gic>; 是错误的,正确的写法是 interrupt-parent = <&gic>; 否则编译会出错。
2. linux-testapp-to-r5-1 相关文档的修改如下:
[platform_info.c]
#define IPI_CHN_BITMASK    0x00000200
#define IPI_DEV_NAME "ff340000.ipi"
#define VRING_DEV_NAME "3ef00000.vring"
#define SHM_DEV_NAME "3ef400000.shm"
[rsc_table.c]
#define RING_TX    0x3EF00000
#define RING_RX    0x3EF04000
3. freeRTOS_echo_test_r5_1 相关文档的修改如下:
[rsc_table.c]:
{RSC_RPROC_MEM, 0x3ef00000, 0x3ef00000, 0x100000, 0},
/*Virtiio device entry*/ { RSC_VDEV, VIRTIO_ID_RPMSG_, 0 RPMSG_IPU_CO_FEATURES, 0, 0, VIRTIO_CONFIG_STATUS_DRIVER_OK, NUM_VRINGS, {0, 0}, },
[lscript.ld]:
psu_ddr_S_AXI_BASEADDR : ORIGIN = 0x3ed40000, LENGTH = 0x00040000
生成BOOT.bin, BIF如下:
the_ROM_image:
         [fsbl_config] a53_x64
         [bootloader] <plnx project>/images/linux/zynqmp_fsbl.elf
         [destination_device=pl] <plnx project/images/linux/download.bit
         [destination_cpu=pmu] <plnx project>/images/linux/pmufw.elf
         [destination_cpu=r5-0] /path/to/freeRTOS_echo_test_r5_0 .elf
         [destination_cpu=r5-1] /path/to/freeRTOS_echo_test_r5_1 .elf
         [destination_cpu=a53-0, exception_level=el-3, trustzone] <plnx project>/images/linux/bl31.elf
         [destination_cpu=a53-0, exception_level=el-2] <plnx project>/images/linux/u-boot.elf
将BOOT.bin、image.ub 和 system.dtb 放入SD卡,从SD卡启动,这时出现了问题。
加载RPU_0的应用程序 freeRTOS_echo_test_r5_0.elf,有以下输出内容:
Starting application...
Try to init remoteproc resource
Init remoteproc resource succeeded
Waiting for events...
说明 RPU_0 应用程序加载没有问题,问题出现在加载 RPU_1 的应用程序 freeRTOS_echo_test_r5_1.elf 的时候,它只有以下输出:
RPU_1 的应用程序没有正常加载。
我不知道是哪里出了问题,是哪里没有修改好吗?我不知道,请问大家是否有遇到类似的问题,你们是怎样解决的,请帮帮我,谢谢!
不知道我是否将问题描述清楚,如果需要我提供更多的信息,请告诉我。
0 项奖励
1 条回复1
292 次查看
注册日期: ‎09-14-2018
回复: ZynqMP Linux Master running on APU with RPMsg in userspace and 2 RPU slaves
目前没做过这个。不过可以试下,
1.  r5_1已经跑起来了,可以加些打印语言看下死在什么代码段上了。
2. 如果不起r5-0, r5-1可以起得来吗?如果可以的话,可能什么地方冲突了
供参考~
0 项奖励
