取消
显示结果
搜索替代
您的意思是:
Observer rampage
760 次查看
注册日期: ‎01-14-2019
eaglego hd的video初始化失败 Exception: Cannot read target memory.
我最近在用eaglego  hd这块板。商家给的white_balance例程(应该不会有错),我编译成功,
然后把程序烧进板子里。
下载程序的方法是::Run as ---launch on hardware
下载完程序之后,SDSOC弹出这个界面
烧录程序时,SDX log的信息如下:
10:11:29 INFO : Registering command handlers for SDK TCF services
10:11:30 INFO : Launching XSCT server: xsct.bat -interactive C:\Users\huangjianhua\test\temp_xsdb_launch_script.tcl
10:11:35 INFO : Validating SDSoC License
10:11:43 INFO : License available for SDSoC
10:11:43 INFO : Validating SDAccel License
10:11:44 INFO : License for SDAccel is unavailable
10:11:45 INFO : XSCT server has started successfully.
10:11:49 INFO : Successfully done setting XSCT server connection channel
10:11:49 INFO : Successfully done setting SDK workspace
10:32:37 INFO : Connected to target on host '127.0.0.1' and port '3121'.
10:32:38 INFO : Jtag cable 'Platform Cable USB 000018ff2c3301' is selected.
10:32:38 INFO : 'jtag frequency' command is executed.
10:32:38 INFO : Sourcing of 'E:/GradDesg/snowleo2/hw/vivado/snowleo2.sdk/snowleo2_wrapper_hw_platform_0/ps7_init.tcl' is done.
10:32:38 INFO : Context for 'APU' is selected.
10:32:38 INFO : System reset is completed.
10:32:41 INFO : 'after 3000' command is executed.
10:32:41 INFO : 'targets -set -filter {jtag_cable_name =~ "Platform Cable USB 000018ff2c3301" && level==0} -index 1' command is executed.
10:32:50 INFO : FPGA configured successfully with bitstream "C:/Users/huangjianhua/test/NO2/Debug/NO2.elf.bit"
10:32:50 INFO : Context for 'APU' is selected.
10:32:50 INFO : Hardware design information is loaded from 'C:/Users/huangjianhua/test/NO2/Debug/_sds/p0/ipi/snowleo2.sdk/snowleo2_wrapper.hdf'.
10:32:52 INFO : 'ps7_init' command is executed.
10:32:52 INFO : Context for processor 'ps7_cortexa9_0' is selected.
10:32:53 INFO : The application 'C:/Users/huangjianhua/test/NO2/Debug/NO2.elf' is downloaded to processor 'ps7_cortexa9_0'.
10:32:53 INFO : ----------------XSDB Script----------------
connect -url tcp:127.0.0.1:3121
source E:/GradDesg/snowleo2/hw/vivado/snowleo2.sdk/snowleo2_wrapper_hw_platform_0/ps7_init.tcl
targets -set -nocase -filter {name =~"APU*" && jtag_cable_name =~ "Platform Cable USB 000018ff2c3301"} -index 0
rst -system
after 3000
fpga -file C:/Users/huangjianhua/test/NO2/Debug/NO2.elf.bit
loadhw C:/Users/huangjianhua/test/NO2/Debug/_sds/p0/ipi/snowleo2.sdk/snowleo2_wrapper.hdf
ps7_init
targets -set -nocase -filter {name =~ "ARM*#0" && jtag_cable_name =~ "Platform Cable USB 000018ff2c3301"} -index 0
dow C:/Users/huangjianhua/test/NO2/Debug/NO2.elf
----------------End of Script----------------
10:32:54 INFO : Memory regions updated for context APU
10:32:54 INFO : Context for processor 'ps7_cortexa9_0' is selected.
10:32:54 INFO : 'con' command is executed.
10:32:54 INFO : ----------------XSDB Script (After Launch)----------------
con
10:32:54 INFO : Launch script is exported to file 'C:\Users\huangjianhua\test\.sdk\launch_scripts\xilinx_sdsoc_application\system_debugger_using_debug_no2.elf_on_local.tcl'
 1.
从上述信息来看,我应该是下载程序成功了吧??
2.
现在我debug发现程序卡在一个地方了。
static INLINE void Xil_Out32(UINTPTR Addr, u32 Value)
volatile u32 *LocalAddr = (volatile u32 *)Addr;
*LocalAddr = Value;          卡在这里了
 Xil_Out32(UINTPTR Addr, u32 Value)操作的地址是0x40010000,可能是DDR访问错误???
0 项奖励
7 条回复7
728 次查看
注册日期: ‎08-02-2007
回复: eaglego hd的HDMI没有显示
你是用Xilinx的HDMI demo还是? HDMI monitor和HDMI cable是好的?
0 项奖励
Observer rampage
716 次查看
注册日期: ‎01-14-2019
@nathanx
1.我用的是威视锐公司提供的白平衡例程,就是摄像头采集数据,然后对图像进行处理,再显示。现在我debug发现程序卡在一个地方了。
报错:Exception: Cannot read target memory. Memory read error at 0x40010000. Cannot access virtual memory. Execution context is running
 2.这个问题我听不懂。我刚接触这块板还没到一个月。没有基础。但是我比较肯定硬件没有问题。
0 项奖励
708 次查看
注册日期: ‎09-14-2018
hi
1. 你debug的设置是怎样的?可否截图看下。
2. Xil_Out32(UINTPTR Addr, u32 Value)操作的地址是什么?
供参考~
0 项奖励
Observer rampage
681 次查看
注册日期: ‎01-14-2019
@chaoz
1.debug截图
不知你说的是不是这张截图呢??
2.Xil_Out32(UINTPTR Addr, u32 Value)操作的地址是0x40010000
0 项奖励
Observer rampage
531 次查看
注册日期: ‎01-14-2019
@chaoz
我发现板子运行了一段时间就自动复位了。应该设置出问题了。但是我又不知道是哪里的问题
0 项奖励
488 次查看
注册日期: ‎09-14-2018
hi @rampage
1. 自动复位和前面所说程序卡住是同一个问题吗?是否可以理解程序卡住的现象其实是因为自动复位了?
2. 自动复位的时间时间间隔是否每次都一样?板子上是否有看门狗复位电路。因为是第三方板子,最好和第三方咨询下。
3. 如果跑别的程序会遇到这个问题吗,可以通过这点来判断是软件问题还是硬件问题。
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
Observer rampage
437 次查看
注册日期: ‎01-14-2019
@chaoz
1.自动复位和前面所说程序卡住是同一个问题
2.自动复位的时间时间间隔是基本每次都一样。但是我debug发现好像每次引发复位(先假设卡死就是复位)的语句不一样。比如:
for (i = 0; i < FRAME_HEIGHT; i++) {
for (j = 0; j < FRAME_WIDTH; j++) {
#pragma AP PIPELINE II = 1
index = (i * FRAME_WIDTH + j);
thisPixel = input[index];
中间省略
output[index]=(Rnew | (Gnew<<8) | (Bnew<<16));
有时在j=4时就卡死了,有时又在j=5时卡死。
至于有没有看门狗电路,我还不知道。客服没回复我,估计是不回复的了。
3.跑别的程序依然会遇到这个问题。
4.我发现只要把HDMI的线拔掉,他就不会卡死。
0 项奖励
