取消
显示结果
搜索替代
您的意思是:
319 次查看
注册日期: ‎10-10-2017
petalinux 中怎么加入u盘
我的petalinux 2018.2 已经建立好了,我也可以访问SD 卡了。可以我不知道怎么访问我的usb 盘
我的硬件是zynq 7000, 板子上有usb 接口。
https://forums.xilinx.com/t5/Embedded-Linux/how-to-install-and-test-usb-disk-on-petalinux/td-p/896545
这里有些回答,但还是没有得到答案。
Kernel Configuration
Ensure the below config parameters are selected
Device Drivers
USB support
    <*> Support for Host-side USB
    <*> EHCI HCD (USB 2.0) support
    <*> USB Mass Storage support
    <*> ChipIdea Highspeed Dual Role Controller
    <*> ChipIdea host controller
        USB Physical Layer drivers --->
        <*> Generic ULPI Transceiver Driver
Devicetree
    usb_0: usb@e0002000 {
         compatible = "xlnx,zynq-usb-2.20.a", "chipidea,usb2";
         clocks = <&&clkc 28>
         dr_mode = "host";
         interrupt-parent = <&&intc>;
         interrupts = <0 21 4>;
         reg = <0xe0002000 0x1000>;
         usb-phy = <&&usb_phy0>;
 usb_phy0: phy0 {
    compatible = "ulpi-phy";
    #phy-cells = <0>;
    view-port = <0x170>;
    drv-vbus;
我会用petalinux-config
但不知道怎么改devicetree
0 项奖励
5 条回复
292 次查看
注册日期: ‎09-14-2018
回复: petalinux 中怎么加入u盘
hi ,
关于修改devicetree:
在petalinux工程目录下,project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
编辑该文件,加入需要修改的部分。
如果提供的信息能解决您的问题,请标记为接受为解决方案
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
242 次查看
注册日期: ‎10-10-2017
谢谢你的回答。
我把文件改成这样, 就是把上面那段添加到system-user.dtsi
文件如下:
/include/ "system-conf.dtsi"
dr_mode = "host";
usb_phy0: phy0 {
#phy-cells = <0>;
drv-vbus;
结果报错如下:
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:14
Checking sstate mirror object availability: 100% |###############| Time: 0:00:01
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_compile: Function failed: do_compile (log file is located at /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.130709)
ERROR: Logfile of failure stored in: /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.130709
Log data follows:
| DEBUG: Executing shell function do_compile
| Error: /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/system-user.dtsi:7.8-20 syntax error
| FATAL ERROR: Unable to parse input tree
| WARNING: /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/run.do_compile.130709:1 exit 1 from 'dtc -I dts -O dtb -R 8 -p 0x1000 -b 0 -i /home/liwenz/alinx/gpio/build/../components/plnx_workspace/device-tree/device-tree -i /home/liwenz/alinx/gpio/build/tmp/work-shared/plnx-zynq7/kernel-source/include -i /home/liwenz/alinx/gpio/build/tmp/work-shared/plnx-zynq7/kernel-source/include -i /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0 -o ${DTS_NAME}.dtb `basename ${DTS_FILE}`.pp'
| ERROR: Function failed: do_compile (log file is located at /home/liwenz/alinx/gpio/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.130709)
ERROR: Task (/home/liwenz/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3004 tasks of which 2991 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
其实别人给我这么说的:
Please follow below steps.
 1 . Open system-user.dtsi and add below device tree changes.
 vim project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
&usb0 {
dr_mode = "host";
status = "okay";
&usb1 {
dr_mode = "host";
status = "okay";
petalinux-build
我这么做,可以 petalinux-build 但没有变化,还是看不到u 盘。
还有devicetree 在petalinux-build 后是不是有个结果文件,这样可以核对检查。
workproject/components/plnx_workspace/device-tree/device-tree 下有个
zynq-7000.dtsi 我以为他就是结果文件
上面推荐那么修改,这个文件没变化。 usb 段是这样的
usb0: usb@e0002000 {
compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
status = "disabled";
clocks = <&clkc 28>;
interrupt-parent = <&intc>;
phy_type = "ulpi";
这里有个disabled , 但我发现串口, sd 都是disable 但他们可以用
0 项奖励
206 次查看
注册日期: ‎05-23-2018
Hi, @liwenz
zynq-7000.dtsi 是工具根据您所导入的hdf文件自动生成的device tree文件,并不是结果文件。您可以通过在system-user.dtsi添加的相关代码对device tree进行修改,重新生成新的dtb文件
根据您的报错信息看来是dtsi文件的语法错误。您可以参考一下这个链接尝试解决您的问题。
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2015-2-1-usb-not-working/td-p/654349
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
0 项奖励
190 次查看
注册日期: ‎09-14-2018
@liwenz
hi ,
1. build 失败是因为device tree语法错误,
提示中有出错的行数。这儿&&clkc 28应该是&clkc 28,后面的也一样。
2. status = "disabled"; 是关闭的。SD可以用是因为在别的地方打开了(具体应该是pcw.dtsi里)。dts文件是向前覆盖的,生效的是最后一次描述的地方.
3. dts编译结果是dtb文件,不是这个zynq-7000.dtsi。dtb可以反编译来核对。不过更简单的方法是在系统启动后 /proc/device-tree目录下查看.
4. 建议看下devicetree相关的东西,下面的链接供参考。
http://xilinx.eetrend.com/d6-xilinx/article/2015-10/9340.html
https://elinux.org/Device_Tree_Usage
0 项奖励
176 次查看
注册日期: ‎10-10-2017
现在我可以看到u盘了
root@gpio:~# random: crng init done
usb 1-1: USB disconnect, device number 2
lsusb
Bus 001 Device 001: ID 1d6b:0002
root@gpio:~# usb 1-1: new high-speed USB device number 3 using ci_hdrc
usb 1-1: New USB device found, idVendor=058f, idProduct=6387
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Mass Storage
usb 1-1: Manufacturer: Generic
usb 1-1: SerialNumber: 086027D0
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1:1.0
scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 61440000 512-byte logical blocks: (31.5 GB/29.3 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
ls
root@gpio:~# ls /mnt
root@gpio:~# mount /dev/sda1 /mnt
System Volume Information boot bootmgr.efi setup.exe support
autorun.inf bootmgr efi sources
root@gpio:~#
文件修改如下:
usb_phy0: usb_phy@0 {
compatible = "usb-nop-xceiv";
#phy-cells = <0>;
//reg = <0xe0002000 0x1000>;
//view-port = <0x170>;
//drv-vbus;
&usb0 {
//compatible = "xlnx,zynq-usb-2.20.a", "chipidea,usb2";
//clocks = <&&clkc 28>
dr_mode = "host";
usb-phy = <&usb_phy0>;
我也不是很懂,但可以看到了。
0 项奖励
