取消
显示结果
搜索替代
您的意思是:
1,422 次查看
注册日期: ‎11-18-2018
petalinux-build时出错
转到解答
第一次使用petalinux,在执行petalinux-build过程中出错,不知道如何解决。
下面是log信息:
wzp@ubuntu:~/zcu104_vcu_plnx$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |############################################| Time: 0:00:02
Loaded 3437 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:13
Parsing of 2552 .bb files complete (2514 cached, 38 parsed). 3441 targets, 139 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:32
Checking sstate mirror object availability: 100% |###############| Time: 0:11:29
NOTE: Executing SetScene Tasks
WARNING: xf86dgaproto-1_2.1-r2 do_package_qa_setscene: Failed to fetch URL file://6b/sstate:xf86dgaproto:aarch64-xilinx-linux:2.1:r2:aarch64:3:6be89ed067d6a73b3014b9c7036eb5f9_package_qa.tgz;downloadfilename=6b/sstate:xf86dgaproto:aarch64-xilinx-linux:2.1:r2:aarch64:3:6be89ed067d6a73b3014b9c7036eb5f9_package_qa.tgz, attempting MIRRORS if available
ERROR: xf86dgaproto-1_2.1-r2 do_package_qa_setscene: Fetcher failure: Unable to find file file://6b/sstate:xf86dgaproto:aarch64-xilinx-linux:2.1:r2:aarch64:3:6be89ed067d6a73b3014b9c7036eb5f9_package_qa.tgz;downloadfilename=6b/sstate:xf86dgaproto:aarch64-xilinx-linux:2.1:r2:aarch64:3:6be89ed067d6a73b3014b9c7036eb5f9_package_qa.tgz anywhere. The paths that were searched were:
/home/wzp/zcu104_vcu_plnx/build/sstate-cache
ERROR: xf86dgaproto-1_2.1-r2 do_package_qa_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/wzp/zcu104_vcu_plnx/build/tmp/work/aarch64-xilinx-linux/xf86dgaproto/1_2.1-r2/temp/log.do_package_qa_setscene.64512
WARNING: Setscene task (/home/wzp/opt/pkg/petalinux/components/yocto/source/aarch64/layers/core/meta/recipes-graphics/xorg-proto/xf86dgaproto_2.1.bb:do_package_qa_setscene) failed with exit code '1' - real task will be run instead
NOTE: Executing RunQueue Tasks
WARNING: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 1 warning message in the logfile:
[log_check] warning: %post(sysvinit-inittab-2.88dsf-r10.zcu104_zynqmp) scriptlet failed, exit status 1
ERROR: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 5 error messages in the logfile:
[log_check] ERROR: ld.so: object 'libpseudo.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/wzp/zcu104_vcu_plnx/build/tmp/work/zcu104_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs.62289
ERROR: Task (/home/wzp/zcu104_vcu_plnx/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6892 tasks of which 5182 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 4 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
0 项奖励
1 个已接受解答
已接受的解答
1,392 次查看
注册日期: ‎09-14-2018
回复: petalinux-build时出错
转到解答
hi @zhuangzhuang
可能还是host 缺少东西,如果是Ubuntu,建议按照下面的指令重新安装一遍,
sudo apt-get update
# Otherwise some of the lib/tools following can't be found on apt-get
sudo apt-get install -y python tofrodos iproute2 gawk xvfb gcc git net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev
#Some of the library can't be found with the name listed on UG1144
sudo apt-get install zlib1g:i386
# If you don't install this one, some warning would be found when source the PetaLinux settings
sudo apt-get install screen
# This is a work-around found for can't open "petalinux-config -c kernel" menu window
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
3 条回复3
1,402 次查看
注册日期: ‎11-18-2018
转到解答
这个错误通过
sudo apt-get install x11proto-xf86dga-dev
得到解决;
但第二个错误:
还不知道如何解决
0 项奖励
1,393 次查看
注册日期: ‎09-14-2018
转到解答
hi @zhuangzhuang
sudo apt-get update
1,370 次查看
注册日期: ‎11-18-2018
转到解答
按照这个解决方案完成后,没有error了,但还会报WARNING: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 1 warning message in the logfile:[log_check] warning: %post(sysvinit-inittab-2.88dsf-r10.zcu104_zynqmp) scriptlet failed, exit status 1
这个warning不影响petalinu的编译,能够通过,能够实现petalinux在FPGA板卡上的运行。
谢谢!!!
0 项奖励
