取消
显示结果
搜索替代
您的意思是:
273 次查看
注册日期: ‎11-23-2018
petalinux2018.2报错缺少libtool,但是libtool已经装好了,并且petalinux已经用过很长时间
转到解答
petalinux2018.2报错缺少libtool,缺少libtool,但是libtool已经装好了,并且petalinux已经用过很长时间,这是什么原因?
重装也是找不到libtool
xxx@xxx-p100-122:~$source /home/xxx/petalinux201802/settings.sh
PetaLinux environment set to '/home/xxx/petalinux201802'
INFO: Checking free disk space
INFO: Checking installed tools
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 219: [: =: unary operator expected
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 302: [: ==: unary operator expected
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 304: [: ==: unary operator expected
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 306: [: ==: unary operator expected
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 251: [: =: unary operator expected
ERROR: You are missing the following system tools required by PetaLinux:
 - libtool
Please check PetaLinux installation guide - required tools and libraries package section for detailed information
INFO: Checking installed development libraries
/home/xxx/petalinux201802/tools/common/petalinux//utils/petalinux-env-check: line 388: [: ==: unary operator expected
Please install them with your operating system package manager, and try again
xxx@xxx-p100-122:~$ sudo apt-get  install libtool
Reading package lists... Done
Building dependency tree
Reading state information... Done
libtool is already the newest version (2.4.6-0.1).
0 upgraded, 0 newly installed, 0 to remove and 215 not upgraded.
xxx@xxx-p100-122:~$
0 项奖励
1 个已接受解答
已接受的解答
241 次查看
注册日期: ‎11-23-2018
回复: petalinux2018.2报错缺少libtool,但是libtool已经装好了,并且petalinux已经用过很长时间
转到解答
参考https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2017-4-Installation-failed-in-Docker/m-p/868701
装了一个libtool-bin,petalinux能work,但是source 过程依然有问题:
xxx@xxx-p100-122:~$ source /home/xxx/petalinux201802/settings.sh
INFO: Checking network and other services
在原帖中查看解决方案
0 项奖励
5 条回复5
262 次查看
注册日期: ‎03-16-2013
转到解答
s删除这个库再重新安装,我前段时间刚发生过类似的事情,我的是另外的库出问题,
0 项奖励
260 次查看
注册日期: ‎11-23-2018
转到解答
@qglyj
sudo apt-get remove libtool
卸载和重装后,问题依然没有解决
0 项奖励
242 次查看
注册日期: ‎11-23-2018
转到解答
在原帖中查看解决方案
0 项奖励
148 次查看
注册日期: ‎09-14-2018
转到解答
hi @yyt
操作系统的版本满足要求吗?
另外可以按照这个流程先完整重装下库试试,
sudo apt-get update
# Otherwise some of the lib/tools following can't be found on apt-get
sudo apt-get install -y python tofrodos iproute2 gawk xvfb gcc git net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev
#Some of the library can't be found with the name listed on UG1144
sudo apt-get install zlib1g:i386
# If you don't install this one, some warning would be found when source the PetaLinux settings
sudo apt-get install screen
# This is a work-around found for can't open "petalinux-config -c kernel" menu window
供参考。
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
133 次查看
注册日期: ‎11-23-2018
转到解答
@chaoz
操作系统是没问题的,petalinux我们已经正常使用一年左右,之前都是没问题的。
库已经装了一遍,没什么问题。
现在虽然在source时报那些问题,但是config  build等过程还是可以用的,先凑合用吧。
谢谢
0 项奖励
