取消
显示结果
搜索替代
您的意思是:
Observer nila
745 次查看
注册日期: ‎12-18-2018
zedboard 不能进入kernel
转到解答
使用xilinx github的uboot,kernel;官方的ramdisk,编译成功后用SD卡启动,在进内核处就停了,请问会是什么问题?
U-Boot 2018.01 (Dec 26 2018 - 15:48:38 +0800)
Model: Zynq Zed Development Board
Board: Xilinx Zynq
Silicon: v3.1
DRAM: ECC disabled 512 MiB
MMC: sdhci@e0100000: 0 (SD)
SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In: serial@e0001000
Out: serial@e0001000
Err: serial@e0001000
Net: ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
eth0: ethernet@e000b000
reading uEnv.txt
302 bytes read in 12 ms (24.4 KiB/s)
Importing environment from SD ...
Device: sdhci@e0100000
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading uEnv.txt
302 bytes read in 13 ms (22.5 KiB/s)
Loaded environment from uEnv.txt
Copying Linux from SD to RAM...
reading uImage
3965808 bytes read in 223 ms (17 MiB/s)
reading devicetree.dtb
5789 bytes read in 15 ms (376 KiB/s)
reading uramdisk.image.gz
5309984 bytes read in 295 ms (17.2 MiB/s)
## Booting kernel from Legacy Image at 02080000 ...
Image Name: Linux-4.14.0-xilinx
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3965744 Bytes = 3.8 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 04000000 ...
Image Name:
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 5309920 Bytes = 5.1 MiB
Load Address: 00000000
Entry Point: 00000000
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Kernel Image ... OK
Loading Ramdisk to 1e609000, end 1eb195e0 ... OK
Loading Device Tree to 1e604000, end 1e60869c ... OK
Starting kernel ...
0 项奖励
1 个已接受解答
已接受的解答
Observer nila
638 次查看
注册日期: ‎12-18-2018
回复: zedboard 不能进入kernel
转到解答
@chaoz
原因是所用的uboot,kernel和fsbl不是同一个版本,都根据vivado改为2017.4版本就可以了。
非常感谢!
0 项奖励
3 条回复3
723 次查看
注册日期: ‎09-14-2018
转到解答
@nila
Linux下面console uart会不会配置错了,导致进入linux后没有打印输出?
0 项奖励
Observer nila
639 次查看
注册日期: ‎12-18-2018
转到解答
@chaoz
非常感谢!
0 项奖励
635 次查看
注册日期: ‎09-14-2018
转到解答
好的,不客气:)也可以将自己的答案标记为解决方案,这样对其他人也有参考作用~~
0 项奖励
