取消
显示结果
搜索替代
您的意思是:
Observer liup1990
260 次查看
注册日期: ‎06-15-2018
zynq7020 nand擦除与读写问题
转到解答
大家好:
       我在ZYNQ XC7z020平台上使用nand flash时遇到一个问题,uboot可以初始化nand flash(型号为:Spansion S34ML01G100TFI00),但是无法擦除与读写,使用uboot命令对其读写或者擦除,程序立刻就卡死了
设备树:
memory-controller@e000e000 {
#address-cells = <0x1>;
#size-cells = <0x1>;
status = "okay";
clock-names = "memclk", "aclk";
clocks = <0x1 0xb 0x1 0x2c>;
compatible = "arm,pl353-smc-r2p1";
interrupt-parent = <0x4>;
interrupts = <0x0 0x12 0x4>;
ranges;
reg = <0xe000e000 0x1000>;
flash@e1000000 {
status = "okay";
compatible = "arm,pl353-nand-r2p1";
reg = <0xe1000000 0x1000000>;
arm,nand-cycle-t0 = <0x4>;
arm,nand-cycle-t1 = <0x4>;
arm,nand-cycle-t2 = <0x1>;
arm,nand-cycle-t3 = <0x2>;
arm,nand-cycle-t4 = <0x2>;
arm,nand-cycle-t5 = <0x2>;
arm,nand-cycle-t6 = <0x4>;
nand-width = <0x8>;
partition@0 {
label = "boot-bin";
reg = <0x0 0x500000>;
partition@1 {
label = "kernel";
reg = <0xf00000 0xa00000>;
partition@2 {
label = "ramdisk";
reg = <0x2300000 0xa00000>;
partition@3 {
label = "devicetree";
reg = <0x3700000 0x500000>;
flash@e2000000 {
status = "disabled";
compatible = "cfi-flash";
reg = <0xe2000000 0x2000000>;
0 项奖励
1 个已接受解答
已接受的解答
Observer liup1990
215 次查看
注册日期: ‎06-15-2018
回复: zynq7020 nand擦除与读写问题
转到解答
问题已解决,更换uboot版本为2017.2,2017.1版本对Spansion S34ML01G1 的支持存在bug,但是对镁光MT29F4GxxAxxDxxx完美支持.
0 项奖励
2 条回复2
Observer liup1990
231 次查看
注册日期: ‎06-15-2018
转到解答
进一步分析,zynq_nand_cmd_function()调用writel()将0x2000800写入地址0xe1b18000时,系统挂了
0 项奖励
Observer liup1990
216 次查看
注册日期: ‎06-15-2018
转到解答
0 项奖励
