取消
显示结果
搜索替代
您的意思是:
338 次查看
注册日期: ‎02-16-2012
【分享】解决错误 undefined reference to symbol '__cxa_throw_bad_array_new_length@@CXXABI_1.3.8'
1. 错误信息
在Makefile里,定义CC为"aarch64-linux-gnu-g++ --sysroot=$(MPSOC_ROOTFS)",编译test.cpp,没有错误。如果使用environment-setup-aarch64-xilinx-linux里的设置,在Makefile里不定义CC,编译test.cpp出现下列错误。
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ make
aarch64-xilinx-linux-gcc  --sysroot=/opt/petalinux/2018.3/zcu106bspsdk/sysroots/aarch64-xilinx-linux -c test.cpp  -O2 -pipe -g -feliminate-unused-debug-types  -g -Wall -O2 -Wall -fpic -fpermissive -I =/usr/include -I =/usr/include/drm -I =/usr/include/libdrm -I =/usr/src/debug/libdrm/2.4.83-r0/libdrm-2.4.83 -I =/usr/src/debug/libdrm/2.4.83-r0/libdrm-2.4.83 -I =/usr/src/debug/libdrm/2.4.83-r0/libdrm-2.4.83/tests -o test.o
aarch64-xilinx-linux-gcc  --sysroot=/opt/petalinux/2018.3/zcu106bspsdk/sysroots/aarch64-xilinx-linux -o egl test.o -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -L =/usr/lib/ -lpthread -ldl -lrt -Wl,-rpath-link, -Wl,-O1 -Wl,--hash-style=gnu -Wl,--allow-multiple-definition -ldrm -lm -lEGL
/opt/petalinux/2018.3/zcu106bspsdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/7.3.0/real-ld: test.o: undefined reference to symbol '__cxa_throw_bad_array_new_length@@CXXABI_1.3.8'
/opt/petalinux/2018.3/zcu106bspsdk/sysroots/aarch64-xilinx-linux/usr/lib/libstdc++.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
Makefile:26: recipe for target 'egl' failed
make: *** [egl] Error 1
2. 编译器信息
在Makefile里,使用编译器aarch64-linux-gnu-g++。
在environment-setup-aarch64-xilinx-linux里,定义CC为"aarch64-xilinx-linux-gcc --sysroot=$SDKTARGETSYSROOT",使用编译器aarch64-xilinx-linux-gcc。
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ which aarch64-xilinx-linux-gcc
/opt/petalinux/2018.3/zcu106bspsdk/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ aarch64-xilinx-linux-gcc --version
aarch64-xilinx-linux-gcc (GCC) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ which aarch64-xilinx-linux-g++
/opt/petalinux/2018.3/zcu106bspsdk/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ aarch64-xilinx-linux-g++ --version
aarch64-xilinx-linux-g++ (GCC) 7.3.0
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ which aarch64-linux-gnu-gcc
/xilinxtool/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/aarch64-linux-gnu-gcc
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$  aarch64-linux-gnu-gcc --version
aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.04-rc3) 7.3.1 20180314
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ which aarch64-linux-gnu-g++
/xilinxtool/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/aarch64-linux-gnu-g++
hankf@xszgs4:/proj/hankf/zcu106/v183/egl$ aarch64-linux-gnu-g++ --version
aarch64-linux-gnu-g++ (Linaro GCC 7.3-2018.04-rc3) 7.3.1 20180314
  3. Makefile
SYSROOT=/xilinxtool/peta/2018.2/zcu106sdk/sysroots/aarch64-xilinx-linux
MPSOC_ROOTFS=/xilinxtool/peta/2018.3/zcu106sdk/sysroots/aarch64-xilinx-linux
CC = aarch64-linux-gnu-g++ --sysroot=$(MPSOC_ROOTFS)
CFLAGS += -g -Wall -O2 -Wall -fpic -fpermissive
CFLAGS += -I ${SYSROOT}/usr/include \
          -I ${SYSROOT}/usr/include/drm \
          -I ${SYSROOT}/usr/include/libdrm
LDFLAGS += -L ${SYSROOT}/usr/lib/ -lpthread -ldl -lrt -Wl,-rpath-link, -Wl,-O1 -Wl,--hash-style=gnu
LDFLAGS += -ldrm -lm -lEGL
4. 解决办法
在environment-setup-aarch64-xilinx-linux里, CC定义成"aarch64-xilinx-linux-gcc --sysroot=SDKTARGETSYSROOT"。
而Makefile里使用gcc去编译cpp文件,导致错误。Makefile里,定义CC为“aarch64-linux-gnu-g++”,也不符合常规。
在Makefile里使用CXX去编译cpp文件,就没有这个问题,其中CXX被定义成"aarch64-xilinx-linux-g++ --sysroot=SDKTARGETSYSROOT"
所以关键是使用aarch64-xilinx-linux-g++编译cpp文件。
0 项奖励
