取消
显示结果
搜索替代
您的意思是:
827 次查看
注册日期: ‎03-16-2013
自定义IP如何编写linux下驱动
转到解答
请问在zynqMP的器件下自定义IP编写linux驱动有没有相关的参考文档
0 项奖励
1 个已接受解答
已接受的解答
844 次查看
注册日期: ‎08-31-2017
回复: 自定义IP如何编写linux下驱动
转到解答
 * devmem2.c: Simple program to read/write from/to any location in memory.
 *  Copyright (C) 2000, Jan-Derk Bakker (jdb@lartmaker.nl)
 * This software has been developed for the LART computing board
 * (http://www.lart.tudelft.nl/). The development has been sponsored by
 * the Mobile MultiMedia Communications (http://www.mmc.tudelft.nl/)
 * and Ubiquitous Communications (http://www.ubicom.tudelft.nl/)
 * projects.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <signal.h>
#include <fcntl.h>
#include <ctype.h>
#include <termios.h>
#include <sys/types.h>
#include <sys/mman.h>
#define FATAL do { fprintf(stderr, "Error at line %d, file %s (%d) [%s]\n", \
  __LINE__, __FILE__, errno, strerror(errno)); exit(1); } while(0)
#define MAP_SIZE 4096UL
#define MAP_MASK (MAP_SIZE - 1)
int main(int argc, char **argv) {
    int fd;
    void *map_base, *virt_addr;
    unsigned long read_result, writeval;
    off_t target;
    int access_type = 'w';
    if(argc < 2) {
        fprintf(stderr, "\nUsage:\t%s { address } [ type [ data ] ]\n"
            "\taddress : memory address to act upon\n"
            "\ttype    : access operation type : [b]yte, [h]alfword, [w]ord\n"
            "\tdata    : data to be written\n\n",
            argv[0]);
        exit(1);
    target = strtoul(argv[1], 0, 0);
    if(argc > 2)
        access_type = tolower(argv[2][0]);
    if((fd = open("/dev/mem", O_RDWR | O_SYNC)) == -1) FATAL;
    printf("/dev/mem opened.\n");
    fflush(stdout);
    /* Map one page */
    map_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, target & ~MAP_MASK);
    if(map_base == (void *) -1) FATAL;
    printf("Memory mapped at address %p.\n", map_base);
    fflush(stdout);
    virt_addr = map_base + (target & MAP_MASK);
    switch(access_type) {
        case 'b':
            read_result = *((unsigned char *) virt_addr);
            break;
        case 'h':
            read_result = *((unsigned short *) virt_addr);
            break;
        case 'w':
            read_result = *((unsigned long *) virt_addr);
            break;
        default:
            fprintf(stderr, "Illegal data type '%c'.\n", access_type);
            exit(2);
    printf("Value at address 0x%X (%p): 0x%X\n", target, virt_addr, read_result);
    fflush(stdout);
    if(argc > 3) {
        writeval = strtoul(argv[3], 0, 0);
            case 'b':
                *((unsigned char *) virt_addr) = writeval;
                break;
            case 'h':
                *((unsigned short *) virt_addr) = writeval;
                break;
            case 'w':
                *((unsigned long *) virt_addr) = writeval;
                break;
        printf("Written 0x%X; readback 0x%X\n", writeval, read_result);
        fflush(stdout);
    if(munmap(map_base, MAP_SIZE) == -1) FATAL;
    close(fd);
    return 0;
其实这个工具的原理也比较简单,就是应用程序通过mmap函数实现对/dev/mem驱动中mmap方法的使用,映射了设备的内存到用户空间,实现对这些物理地址的读写操作。使用方法:
  1. 用法: devmem2 { address } [ type [ data ] ]
  2. address : 物理地址
  3. 如果是要修改该地址的数据,需要填入下面的参数;如果只是读取,省略即可
  4. type :要访问的数据类型 : [b]yte, [h]alfword, [w]ord
  5. data :想要写入的数据
通过使用,发现IO内存和物理内核都可以读写。
在原帖中查看解决方案
6 条回复6
811 次查看
注册日期: ‎08-31-2017
转到解答
因为编写自定义的驱动比较复杂,目前xilinx提供了基于应用的调用办法,就是操作/dev/mem 和/dev/UIO这个两个设备节点,具体的用法你可以去wiki.xilinx.com上去看一下,核心就是基于mmap在linux下直接操作physical address,非常的方便。
786 次查看
注册日期: ‎03-16-2013
转到解答
我是个初学者,有没有一个具体的例子可供参考呢,谢谢
0 项奖励
845 次查看
注册日期: ‎08-31-2017
转到解答
 * projects.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <signal.h>
#include <fcntl.h>
#include <ctype.h>
    int fd;
    off_t target;
    if(argc < 2) {
            argv[0]);
        exit(1);
    if(argc > 2)
    fflush(stdout);
    /* Map one page */
    fflush(stdout);
        case 'b':
            break;
        case 'h':
            break;
        case 'w':
            break;
        default:
            exit(2);
    fflush(stdout);
    if(argc > 3) {
            case 'b':
                break;
            case 'h':
                break;
            case 'w':
                break;
        fflush(stdout);
    close(fd);
    return 0;
  2. address : 物理地址
  5. data :想要写入的数据
在原帖中查看解决方案
768 次查看
注册日期: ‎03-16-2013
转到解答
谢谢,我学习下
0 项奖励
305 次查看
注册日期: ‎04-15-2019
转到解答
您好,我现在也在给自定义IP核编写linux下驱动,我也是再用这个解答的方法,您后面有使用这种方法吗?我也是初学者,看了好几天都没有头绪能否方便加个联系方式联系下2273667502。打扰您了
0 项奖励
231 次查看
注册日期: ‎04-15-2019
转到解答
您好,我也在弄这个类似的东西,但是缺乏经验,能否加个联系方式2273667502(QQ)指导下,非诚感谢!
0 项奖励
