取消
显示结果
搜索替代
您的意思是:
431 次查看
注册日期: ‎10-19-2018
zcu106 rootfs initramfs sd card
我把zcu106的官网BSP进行petalinux-config时,把rootfs的initramfs修改为sd card后产生boot、image和rootfs文件,之后把boot和image文件拷贝到sd卡的fat分区,而把rootfs文件拷贝到SD卡的ext分区,zcu106板块启动不了,出现以下错误,这是怎么造成的,需要怎样解决?
0 项奖励
7 条回复7
Mentor
Mentor
422 次查看
注册日期: ‎06-17-2013
Re: zcu106 rootfs initramfs sd card
Hi @shengdishd
Would you share the followings ?
- u-boot's log
- The value of Ketnel Bootargs on petalinux-config
  - run the following command
    $ petalinux-config
    -> Enter DTG Settings -> Enter Kernel Bootargs
Best regards,
0 项奖励
412 次查看
注册日期: ‎10-19-2018
- u-boot's log,这个在哪里啊?
- The value of Kernel Bootargs on petalinux-config,在下面
0 项奖励
Mentor
Mentor
397 次查看
注册日期: ‎06-17-2013
Hi @shengdishd
You can find u-boot's log on serial console before starting linux kernel log which you already mentioned before.
[note]
You can access FPGA via usb cable by terminal software (ex. tera term) on Windows.
Best regards,
0 项奖励
365 次查看
注册日期: ‎10-19-2018
u-boot's log和The value of Kernel Bootargs on petalinux-config,在下面
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 Jun 11 2019 - 07:32:42
NOTICE: ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x10080000
NOTICE: BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790
NOTICE: BL31: Built : 00:21:46, Sep 27 2019
PMUFW: v1.1
U-Boot 2019.01 (Sep 27 2019 - 00:22:41 +0000)
Model: ZynqMP ZCU106 RevA
Board: Xilinx ZynqMP
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu7ev
MMC: mmc@ff170000: 0
Loading Environment from SPI Flash... SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Reset reason: EXTERNAL
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in ROM is ff:ff:ff:ff:ff:ff
Address in environment is 00:0a:35:00:22:01
eth0: ethernet@ff0e0000
Device: mmc@ff170000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
18270272 bytes read in 1208 ms (14.4 MiB/s)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x10000104
Data Size: 18217472 Bytes = 17.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: fe4c4489d6b5636d3d7483ed5fea5c09fb95651e
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x1115fc08
Data Size: 50884 Bytes = 49.7 KiB
Hash algo: sha1
Hash value: c9e42f8e264e7dd77a22be5a58c28cba95b5aa28
Booting using the fdt blob at 0x1115fc08
Loading Kernel Image ... OK
Loading Device Tree to 000000007dd8e000, end 000000007dd9d6c3 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Fri Sep 27 00:22:38 UTC 2019
[ 0.000000] Machine model: ZynqMP ZCU106 RevA
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 1700 MiB at 0x0000000013800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x37c with crng_init=0
[ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1033987
[ 0.000000] Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x0f800000-0x13800000] (64MB)
[ 0.000000] Memory: 2303688K/4193280K available (10812K kernel code, 638K rwdata, 5436K rodata, 832K init, 509K bss, 148792K reserved, 1740800K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008256] Console: colour dummy device 80x25
[ 0.012377] console [tty0] enabled
[ 0.015744] bootconsole [cdns0] disabled
[ 0.019656] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.019670] pid_max: default: 32768 minimum: 301
[ 0.019786] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.019804] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.020511] ASID allocator initialised with 32768 entries
[ 0.020563] rcu: Hierarchical SRCU implementation.
[ 0.020897] EFI services will not be available.
[ 0.021017] smp: Bringing up secondary CPUs ...
[ 0.021293] Detected VIPT I-cache on CPU1
[ 0.021321] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.021625] Detected VIPT I-cache on CPU2
[ 0.021644] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.021932] Detected VIPT I-cache on CPU3
[ 0.021951] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.021995] smp: Brought up 1 node, 4 CPUs
[ 0.022028] SMP: Total of 4 processors activated.
[ 0.022036] CPU features: detected: 32-bit EL0 Support
[ 0.023559] CPU: All CPU(s) started at EL2
[ 0.023575] alternatives: patching kernel code
[ 0.024446] devtmpfs: initialized
[ 0.030041] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030065] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.065363] xor: measuring software checksum speed
[ 0.103977] 8regs : 2375.000 MB/sec
[ 0.144005] 8regs_prefetch: 2052.000 MB/sec
[ 0.184034] 32regs : 2724.000 MB/sec
[ 0.224063] 32regs_prefetch: 2308.000 MB/sec
[ 0.224071] xor: using function: 32regs (2724.000 MB/sec)
[ 0.224086] pinctrl core: initialized pinctrl subsystem
[ 0.224692] NET: Registered protocol family 16
[ 0.224966] audit: initializing netlink subsys (disabled)
[ 0.225034] audit: type=2000 audit(0.216:1): state=initialized audit_enabled=0 res=1
[ 0.225455] cpuidle: using governor menu
[ 0.225592] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.225605] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.226293] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.241075] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.308291] raid6: int64x1 gen() 446 MB/s
[ 0.376289] raid6: int64x1 xor() 453 MB/s
[ 0.444341] raid6: int64x2 gen() 681 MB/s
[ 0.512383] raid6: int64x2 xor() 600 MB/s
[ 0.580417] raid6: int64x4 gen() 981 MB/s
[ 0.648445] raid6: int64x4 xor() 737 MB/s
[ 0.716525] raid6: int64x8 gen() 1162 MB/s
[ 0.784561] raid6: int64x8 xor() 759 MB/s
[ 0.852596] raid6: neonx1 gen() 734 MB/s
[ 0.920647] raid6: neonx1 xor() 880 MB/s
[ 0.988731] raid6: neonx2 gen() 1127 MB/s
[ 1.056771] raid6: neonx2 xor() 1173 MB/s
[ 1.124836] raid6: neonx4 gen() 1480 MB/s
[ 1.192873] raid6: neonx4 xor() 1418 MB/s
[ 1.260933] raid6: neonx8 gen() 1562 MB/s
[ 1.328974] raid6: neonx8 xor() 1459 MB/s
[ 1.328982] raid6: using algorithm neonx8 gen() 1562 MB/s
[ 1.328990] raid6: .... xor() 1459 MB/s, rmw enabled
[ 1.328997] raid6: using neon recovery algorithm
[ 1.329215] xilinx-gpio a0060000.gpio: Input clock not found
[ 1.329260] xilinx-gpio a0061000.gpio: Input clock not found
[ 1.329299] xilinx-gpio a0062000.gpio: Input clock not found
[ 1.329336] xilinx-gpio a0063000.gpio: Input clock not found
[ 1.329926] SCSI subsystem initialized
[ 1.330087] usbcore: registered new interface driver usbfs
[ 1.330123] usbcore: registered new interface driver hub
[ 1.330159] usbcore: registered new device driver usb
[ 1.330230] media: Linux media interface: v0.10
[ 1.330259] videodev: Linux video capture interface: v2.00
[ 1.330289] pps_core: LinuxPPS API ver. 1 registered
[ 1.330297] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.330318] PTP clock support registered
[ 1.330346] EDAC MC: Ver: 3.0.0
[ 1.331014] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.331248] FPGA manager framework
[ 1.331423] Advanced Linux Sound Architecture Driver Initialized.
[ 1.331699] Bluetooth: Core ver 2.22
[ 1.331728] NET: Registered protocol family 31
[ 1.331736] Bluetooth: HCI device and connection manager initialized
[ 1.331748] Bluetooth: HCI socket layer initialized
[ 1.331758] Bluetooth: L2CAP socket layer initialized
[ 1.331781] Bluetooth: SCO socket layer initialized
[ 1.332087] clocksource: Switched to clocksource arch_sys_counter
[ 1.332163] VFS: Disk quotas dquot_6.6.0
[ 1.332206] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.336606] NET: Registered protocol family 2
[ 1.336996] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.337049] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.337257] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.337638] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.337704] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.337782] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.337934] NET: Registered protocol family 1
[ 1.338153] RPC: Registered named UNIX socket transport module.
[ 1.338162] RPC: Registered udp transport module.
[ 1.338170] RPC: Registered tcp transport module.
[ 1.338177] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.338754] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.338903] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.339765] Initialise system trusted keyrings
[ 1.340039] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.340752] NFS: Registering the id_resolver key type
[ 1.340769] Key type id_resolver registered
[ 1.340777] Key type id_legacy registered
[ 1.340789] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.340810] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 2.423517] NET: Registered protocol family 38
[ 2.482146] Key type asymmetric registered
[ 2.482156] Asymmetric key parser 'x509' registered
[ 2.482202] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.482215] io scheduler noop registered
[ 2.482223] io scheduler deadline registered
[ 2.482258] io scheduler cfq registered (default)
[ 2.482266] io scheduler mq-deadline registered
[ 2.482275] io scheduler kyber registered
[ 2.484000] xilinx-frmbuf b0000000.v_frmbuf_wr: failed to get ap_clk (-517)
[ 2.484046] xilinx-frmbuf b0010000.v_frmbuf_rd: failed to get ap_clk (-517)
[ 2.510053] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.513722] xlnx-sdi-tx a0040000.v_smpte_uhdsdi_tx_ss: failed to get s_axi_aclk -517
[ 2.513947] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.518237] brd: module loaded
[ 2.522064] loop: module loaded
[ 2.523050] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.524447] libphy: Fixed MDIO Bus: probed
[ 2.525745] tun: Universal TUN/TAP device driver, 1.6
[ 2.525868] CAN device driver interface
[ 2.526938] usbcore: registered new interface driver asix
[ 2.526974] usbcore: registered new interface driver ax88179_178a
[ 2.527006] usbcore: registered new interface driver cdc_ether
[ 2.527039] usbcore: registered new interface driver net1080
[ 2.527073] usbcore: registered new interface driver cdc_subset
[ 2.527104] usbcore: registered new interface driver zaurus
[ 2.527147] usbcore: registered new interface driver cdc_ncm
[ 2.527699] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.527710] ehci-pci: EHCI PCI platform driver
[ 2.528031] usbcore: registered new interface driver uas
[ 2.528072] usbcore: registered new interface driver usb-storage
[ 2.528679] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 2.528752] i2c /dev entries driver
[ 2.529115] xilinx-video amba_pl@0:vcap_sdi: /amba_pl@0/vcap_sdi/ports/port@0 initialization failed
[ 2.529129] xilinx-video amba_pl@0:vcap_sdi: DMA initialization failed
[ 2.530233] xilinx-sdirxss a0030000.v_smpte_uhdsdi_rx_ss: failed to get s_axi_clk (-517)
[ 2.530633] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 2.530647] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[ 2.530896] usbcore: registered new interface driver uvcvideo
[ 2.530905] USB Video Class driver (1.1.1)
[ 2.531509] Bluetooth: HCI UART driver ver 2.3
[ 2.531519] Bluetooth: HCI UART protocol H4 registered
[ 2.531527] Bluetooth: HCI UART protocol BCSP registered
[ 2.531555] Bluetooth: HCI UART protocol LL registered
[ 2.531563] Bluetooth: HCI UART protocol ATH3K registered
[ 2.531589] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.531640] Bluetooth: HCI UART protocol Intel registered
[ 2.531666] Bluetooth: HCI UART protocol QCA registered
[ 2.531705] usbcore: registered new interface driver bcm203x
[ 2.531741] usbcore: registered new interface driver bpa10x
[ 2.531776] usbcore: registered new interface driver bfusb
[ 2.531813] usbcore: registered new interface driver btusb
[ 2.531822] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 2.531874] usbcore: registered new interface driver ath3k
[ 2.532001] EDAC MC: ECC not enabled
[ 2.532199] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 2.532916] sdhci: Secure Digital Host Controller Interface driver
[ 2.532925] sdhci: Copyright(c) Pierre Ossman
[ 2.532933] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.533287] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.533338] zynqmp_firmware_probe Platform Management API v1.1
[ 2.533349] zynqmp_firmware_probe Trustzone version v1.0
[ 2.536145] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 2.557779] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 2.558265] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 2.558286] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 2.558286]
[ 2.558477] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 2.558646] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 2.558862] usbcore: registered new interface driver usbhid
[ 2.558871] usbhid: USB HID core driver
[ 2.561383] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 2.561796] usbcore: registered new interface driver snd-usb-audio
[ 2.563466] xlnx_formatter_pcm a0000000.audio_formatter: sound card device will use DAI link: v_uhdsdi_audio
[ 2.564510] xlnx_formatter_pcm a0000000.audio_formatter: sound card device will use DAI link: v_uhdsdi_audio
[ 2.564650] xlnx_formatter_pcm a0000000.audio_formatter: pcm platform device registered
[ 2.564930] xlnx-sdi-audio a0020000.v_uhdsdi_audio: xlnx sdi codec dai component registered
[ 2.565256] xlnx_snd_card xlnx_snd_card.0.auto: ASoC: CODEC DAI xlnx_sdi_tx not registered
[ 2.565270] xlnx_snd_card xlnx_snd_card.0.auto: xlnx-sdi-snd-card-0 registration failed
[ 2.565335] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 2.565764] Initializing XFRM netlink socket
[ 2.565845] NET: Registered protocol family 10
[ 2.566195] Segment Routing with IPv6
[ 2.566295] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.566622] NET: Registered protocol family 17
[ 2.566638] NET: Registered protocol family 15
[ 2.566658] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.566706] can: controller area network core (rev 20170425 abi 9)
[ 2.566737] NET: Registered protocol family 29
[ 2.566746] can: raw protocol (rev 20170425)
[ 2.566754] can: broadcast manager protocol (rev 20170425 t)
[ 2.566765] can: netlink gateway (rev 20170425) max_hops=1
[ 2.566827] Bluetooth: RFCOMM TTY layer initialized
[ 2.566840] Bluetooth: RFCOMM socket layer initialized
[ 2.566858] Bluetooth: RFCOMM ver 1.11
[ 2.566869] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.566877] Bluetooth: BNEP filters: protocol multicast
[ 2.566887] Bluetooth: BNEP socket layer initialized
[ 2.566895] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.566905] Bluetooth: HIDP socket layer initialized
[ 2.567019] 9pnet: Installing 9P2000 support
[ 2.567041] Key type dns_resolver registered
[ 2.567436] registered taskstats version 1
[ 2.567444] Loading compiled-in X.509 certificates
[ 2.567774] Btrfs loaded, crc32c=crc32c-generic
[ 2.574113] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249375) is a xuartps
[ 3.965781] console [ttyPS0] enabled
[ 3.969814] GPIO IRQ not connected
[ 3.973217] XGpio: gpio@a0060000: registered, base is 510
[ 3.978796] GPIO IRQ not connected
[ 3.982202] XGpio: gpio@a0061000: registered, base is 509
[ 3.987773] GPIO IRQ not connected
[ 3.991176] XGpio: gpio@a0062000: registered, base is 508
[ 3.996777] GPIO IRQ not connected
[ 4.000180] XGpio: gpio@a0063000: registered, base is 504
[ 4.006487] of-fpga-region fpga-full: FPGA Region probed
[ 4.012716] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 4.019304] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 4.026417] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 4.033524] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 4.040636] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 4.047742] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 4.054852] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 4.061958] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 4.069066] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 4.076249] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 4.083363] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 4.090466] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 4.097581] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 4.104688] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 4.111799] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 4.118909] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 4.126019] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 4.133118] xilinx-frmbuf b0000000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[ 4.140584] xilinx-frmbuf b0000000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 4.149231] xilinx-frmbuf b0010000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV
[ 4.156691] xilinx-frmbuf b0010000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 4.165392] xlnx-mixer a0070000.v_mix: vtc bridge property not present
[ 4.172041] xlnx-mixer a0070000.v_mix: Xilinx Mixer driver probed success
[ 4.179200] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.185814] [drm] No driver support for vblank timestamp query.
[ 4.191846] xlnx-drm xlnx-drm.0: bound a0070000.v_mix (ops 0xffffff8008bcb9e8)
[ 4.199095] xlnx-drm xlnx-drm.0: bound a0040000.v_smpte_uhdsdi_tx_ss (ops 0xffffff8008bcbff0)
[ 4.207627] xlnx-mixer a0070000.v_mix: fbdev is not initialized
[ 4.213755] [drm] Initialized xlnx 1.0.0 20130509 for a0070000.v_mix on minor 0
[ 4.221397] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 4.231329] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 4.242004] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 4.250045] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 4.258377] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 4.270821] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 4.283510] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 4.293690] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 4.300664] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.307272] [drm] No driver support for vblank timestamp query.
[ 4.313255] xlnx-drm xlnx-drm.1: bound fd4a0000.zynqmp-display (ops 0xffffff8008bcf800)
[ 5.400101] [drm] Cannot find any crtc or sizes
[ 5.404843] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 1
[ 5.412952] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 5.421929] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 5.429824] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 5.438788] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.449234] scsi host0: ahci-ceva
[ 5.452817] scsi host1: ahci-ceva
[ 5.456288] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[ 5.464209] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[ 5.472775] m25p80 spi0.0: found n25q512a, expected m25p80
[ 5.478641] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 5.483542] 4 fixed-partitions partitions found on MTD device spi0.0
[ 5.489893] Creating 4 MTD partitions on "spi0.0":
[ 5.494686] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 5.500905] 0x000000100000-0x000000600000 : "qspi-linux"
[ 5.506601] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 5.512820] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[ 5.520662] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 5.528015] libphy: MACB_mii_bus: probed
[ 5.534081] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[ 5.547128] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[ 5.557258] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 5.563785] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 5.570270] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 5.576751] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 5.584630] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 5.590481] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 5.598607] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.604103] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 5.612093] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 5.621510] xhci-hcd xhci-hcd.1.auto: irq 57, io mem 0xfe200000
[ 5.627628] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 5.635896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.643122] usb usb1: Product: xHCI Host Controller
[ 5.647997] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[ 5.654699] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 5.659858] hub 1-0:1.0: USB hub found
[ 5.663636] hub 1-0:1.0: 1 port detected
[ 5.667746] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.673241] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 5.680905] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 5.687632] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 5.695897] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.703115] usb usb2: Product: xHCI Host Controller
[ 5.707990] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[ 5.714683] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 5.719802] hub 2-0:1.0: USB hub found
[ 5.723567] hub 2-0:1.0: 1 port detected
[ 5.728599] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[ 5.735858] pca953x 0-0020: Linked as a consumer to regulator.0
[ 5.742518] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[ 5.749769] pca953x 0-0021: Linked as a consumer to regulator.0
[ 5.757068] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.763851] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.770647] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.777436] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.784219] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.786293] ata2: SATA link down (SStatus 0 SControl 330)
[ 5.791011] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.796001] ata1: SATA link down (SStatus 0 SControl 330)
[ 5.802762] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.814512] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.821305] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.828106] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.834485] i2c i2c-0: Added multiplexed i2c bus 3
[ 5.839906] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 5.846692] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.853486] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.860277] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.867055] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.873844] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.880630] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.887430] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.893810] i2c i2c-0: Added multiplexed i2c bus 4
[ 5.916204] random: fast init done
[ 5.935330] i2c i2c-0: Added multiplexed i2c bus 5
[ 5.940257] i2c i2c-0: Added multiplexed i2c bus 6
[ 5.945051] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 5.952387] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[ 5.960044] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 5.966777] i2c i2c-1: Added multiplexed i2c bus 7
[ 5.971777] i2c i2c-1: Added multiplexed i2c bus 8
[ 5.976705] i2c i2c-1: Added multiplexed i2c bus 9
[ 5.995555] si570 10-005d: registered, current frequency 148500000 Hz
[ 6.002029] i2c i2c-1: Added multiplexed i2c bus 10
[ 6.007118] si5324 11-0069: si5328 probed
[ 6.072219] si5324 11-0069: si5328 probe successful
[ 6.077124] i2c i2c-1: Added multiplexed i2c bus 11
[ 6.082214] i2c i2c-1: Added multiplexed i2c bus 12
[ 6.087218] i2c i2c-1: Added multiplexed i2c bus 13
[ 6.092231] i2c i2c-1: Added multiplexed i2c bus 14
[ 6.097106] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 6.105008] i2c i2c-1: Added multiplexed i2c bus 15
[ 6.110014] i2c i2c-1: Added multiplexed i2c bus 16
[ 6.115027] i2c i2c-1: Added multiplexed i2c bus 17
[ 6.120412] i2c i2c-1: Added multiplexed i2c bus 18
[ 6.125422] i2c i2c-1: Added multiplexed i2c bus 19
[ 6.130434] i2c i2c-1: Added multiplexed i2c bus 20
[ 6.135435] i2c i2c-1: Added multiplexed i2c bus 21
[ 6.140442] i2c i2c-1: Added multiplexed i2c bus 22
[ 6.145319] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 6.152914] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[ 6.159148] xilinx-video amba_pl@0:vcap_sdi: device registered
[ 6.165272] xilinx-video amba_pl@0:vcap_sdi: Entity type for entity a0030000.v_smpte_uhdsdi_rx_ss was not initialized!
[ 6.175975] xilinx-sdirxss a0030000.v_smpte_uhdsdi_rx_ss: Xilinx SDI Rx Subsystem device found!
[ 6.184835] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 6.195011] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[ 6.203491] xilinx-video amba_pl@0:vcap_sdi: Entity type for entity a0080000.v_proc_ss was not initialized!
[ 6.213471] xilinx-vpss-scaler a0080000.v_proc_ss: Num Hori Taps 8
[ 6.219655] xilinx-vpss-scaler a0080000.v_proc_ss: Num Vert Taps 8
[ 6.225834] xilinx-vpss-scaler a0080000.v_proc_ss: VPSS Scaler Probe Successful
[ 6.233440] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[ 6.242618] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
[ 6.251870] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[ 6.259317] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[ 6.300061] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 6.313909] xlnx-sdi-audio a0010000.v_uhdsdi_audio: xlnx sdi codec dai component registered
[ 6.322847] xlnx_snd_card xlnx_snd_card.0.auto: a0010000.v_uhdsdi_audio <-> snd-soc-dummy-dai mapping ok
[ 6.332633] xlnx_snd_card xlnx_snd_card.0.auto: a0020000.v_uhdsdi_audio <-> snd-soc-dummy-dai mapping ok
[ 6.342638] xlnx_snd_card xlnx_snd_card.0.auto: xlnx-sdi-snd-card-0 registered
[ 6.352286] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.359307] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-09-27 05:48:34 UTC (1569563314)
[ 6.368190] of_cfs_init
[ 6.370641] of_cfs_init: OK
[ 6.373578] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.411789] mmc0: new high speed SDHC card at address aaaa
[ 6.417754] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[ 6.426299] mmcblk0: p1 p2
[ 6.512605] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.519137] clk: Not disabling unused clocks
[ 6.523404] ALSA device list:
[ 6.526367] #0: DisplayPort monitor
[ 6.530024] #1: xlnx-sdi-snd-card-0
[ 6.533956] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 6.542569] cfg80211: failed to load regulatory.db
[ 6.547455] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 6.554935] Please append a correct "root=" boot option; here are the available partitions:
[ 6.560097] [drm] Cannot find any crtc or sizes
[ 6.563289] 0100 65536 ram0
[ 6.567804] (driver?)
[ 6.573899] 0101 65536 ram1
[ 6.573901] (driver?)
[ 6.579989] 0102 65536 ram2
[ 6.579990] (driver?)
[ 6.586087] 0103 65536 ram3
[ 6.586089] (driver?)
[ 6.592181] 0104 65536 ram4
[ 6.592182] (driver?)
[ 6.598266] 0105 65536 ram5
[ 6.598268] (driver?)
[ 6.604360] 0106 65536 ram6
[ 6.604362] (driver?)
[ 6.610450] 0107 65536 ram7
[ 6.610451] (driver?)
[ 6.616548] 0108 65536 ram8
[ 6.616550] (driver?)
[ 6.622638] 0109 65536 ram9
[ 6.622639] (driver?)
[ 6.628736] 010a 65536 ram10
[ 6.628738] (driver?)
[ 6.634913] 010b 65536 ram11
[ 6.634914] (driver?)
[ 6.641100] 010c 65536 ram12
[ 6.641101] (driver?)
[ 6.647283] 010d 65536 ram13
[ 6.647284] (driver?)
[ 6.653469] 010e 65536 ram14
[ 6.653470] (driver?)
[ 6.659653] 010f 65536 ram15
[ 6.659655] (driver?)
[ 6.665844] 1f00 1024 mtdblock0
[ 6.665846] (driver?)
[ 6.672376] 1f01 5120 mtdblock1
[ 6.672377] (driver?)
[ 6.678908] 1f02 128 mtdblock2
[ 6.678909] (driver?)
[ 6.685440] 1f03 6016 mtdblock3
[ 6.685442] (driver?)
[ 6.691972] b300 15558144 mmcblk0
[ 6.691973] driver: mmcblk
[ 6.698766] b301 4096000 mmcblk0p1 bdc81bef-01
[ 6.698767]
[ 6.705562] b302 11457536 mmcblk0p2 bdc81bef-02
[ 6.705563]
[ 6.712350] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 6.720605] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.19.0-xilinx-v2019.1 #1
[ 6.727815] Hardware name: ZynqMP ZCU106 RevA (DT)
[ 6.732597] Call trace:
[ 6.735042] dump_backtrace+0x0/0x148
[ 6.738692] show_stack+0x14/0x20
[ 6.742000] dump_stack+0x90/0xb4
[ 6.745307] panic+0x120/0x268
[ 6.748355] mount_block_root+0x1b0/0x260
[ 6.752356] mount_root+0x11c/0x148
[ 6.755837] prepare_namespace+0x14c/0x194
[ 6.759926] kernel_init_freeable+0x1b8/0x1d4
[ 6.764276] kernel_init+0x10/0xfc
[ 6.767668] ret_from_fork+0x10/0x18
[ 6.771238] SMP: stopping secondary CPUs
[ 6.775151] Kernel Offset: disabled
[ 6.778631] CPU features: 0x0,20802004
[ 6.782372] Memory Limit: none
[ 6.785414] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
这有什么问题吗,要怎么修改啊?
0 项奖励
Mentor
Mentor
337 次查看
注册日期: ‎06-17-2013
Hi @shengdishd
It seems partition issue.
Can you share detail partition information of SD card ?
[ 6.698767]
[ 6.705563]
Best regards,
0 项奖励
324 次查看
注册日期: ‎10-19-2018
我是按下面网页的步骤进行分区的
https://blog.csdn.net/lulugay/article/details/83240981
其中Free Space Proceeding为4M,FAT32为4000M,EXT4为余下的,SD卡总共为16000M。
你看下有什么问题没?
0 项奖励
Mentor
Mentor
261 次查看
注册日期: ‎06-17-2013
Hi @shengdishd
Would you make sure the followings ?
- Make sure partition table whether it is msdos format or not.
- Run fsck command to make sure and fix a patition for partion0 and patition1 on linux.
Best regards,
0 项奖励
